We Pierced Engine Oil Reservoir (Crankcase) - Pictures 1Sf |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 17:39 | # 1 |
tlp |
On the way to the Izmit from Sakarya, we passed the lights of the wife (he was going from the front) and left at the center of the road with a speed of 80-90 Km from the left lane. The friend survived the incident by breaking the crankcase, but I could not have been so lucky, unfortunately. As I hit the stone, he took it under the car, hit it hard on the oil chamber and broke it We dragged the stone about 100 Mt, but how loudly we dragged it. I couldn't understand what it was. When the reservoir broke, all the oil was drained, I stopped the car as soon as I pulled over I pulled the car over the wedges I found on the side and the bowl I still don't mind, what is a big stone doing right in the middle of the road ?? Has anyone seen it? The servant of a god did not bother to pull that stone aside! I hope and construction will just bypass the situation with crankcase change |
| 08.05.2020 17:39 | # 2 |
Get well soon...
| 08.05.2020 17:39 | # 3 |
Well, my hod, if God came to the wheel, he did somersaults, but I don't think there will be a problem with the engine, you stopped immediately, it will be resolved with the crankcase change.
| 08.05.2020 17:39 | # 4 |
tlp |
Thanks I didn't even understand what happened in the first place As you said, if I came to the wheel, or if I did maneuver or something, it could cause different problems. After stopping I was able to stop but did not drain the oil immediately He drained all the oil from where I stopped I hope it ends with sump. It was already an oil change :) |
| 08.05.2020 17:39 | # 5 |
I believe they intentionally put those stones there, and a similar incident happened to me. When I passed from sakarya to soup, I passed the wiping stone. |
| 08.05.2020 17:39 | # 6 |
Alicilik |
I hope you get past, as much as you wish, hodja. It is not clear when the benefit of crankcase protection will be great. |
| 08.05.2020 17:39 | # 7 |
Get well soon. crankcase protective requirement.
| 08.05.2020 17:39 | # 8 |
Get well soon .
| 08.05.2020 17:39 | # 9 |
I hope that it will be as simple as you wish it will be past. Unfortunately, there are people who are very irresponsible. |
| 08.05.2020 17:39 | # 10 |
Barut |
I hope you will save it only with a sump.
| 08.05.2020 17:39 | # 11 |
tlp |
We survived the situation with a crankcase change May Allah hide worse
| 08.05.2020 17:39 | # 12 |
Get well soon ..
| 08.05.2020 17:39 | # 13 |
get well soon, Alllah bless bigger ones ...
| 08.05.2020 17:39 | # 14 |
volkan22 |
Whether it's past, they came to me one day, when they were on the highway, they say what the door of the house is on the road. The vehicles that go up are because of these insecurity: S is cheap
| 08.05.2020 17:39 | # 15 |
Amaan allah protected or if he had come to the wheel line .. my brother had also come to the hunters during the metrobus work, the same thing had escaped from that stone at the last moment but the tire had hit the edge, the tire had been split apart, no other fault would occur. I hit the bottom of the car once, every time I started the indicator, the oil level that shows the oil level is seven heads of oil and then it went away, did it have a crankcase protection? i have my vehicle 206 hdi
| 08.05.2020 17:39 | # 16 |
tlp |
When I got a crankcase I used it like that
| 08.05.2020 17:39 | # 17 |
If the crankcase was the case, you would probably have saved the most protection. Bide my car 206 hdi, the diesel engine will fit the bottom of the ground so close to the ground is a little high, it hits directly, but when the protection is less, the human head is comfortable. Get well soon..
| 08.05.2020 17:39 | # 18 |
tlp |
Friends pictures This crankcase ![]() These are the havoc caused by ![]() ![]() ![]() Buddha new sump ![]() 230 TL sump 55 tl oil (total 10/40) 15 tl oil filter 100 TL labor I am not counting the costs of the oil already changed |
| 08.05.2020 17:39 | # 19 |
fexzi |
May my Lord bless you
| 08.05.2020 17:39 | # 20 |
reality59 |
what the hell did he get out of the hole
