We got out of the examination (we went) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 21:08 | # 1 |
| 08.05.2020 21:08 | # 2 |
Depending on the minister. Normally, they quickly check the lamps and look at it for whatever reason you are, but if you hit one of the hair, it might find another defect again. They left our friend on the examination that the brake lights were burning pink even though they were original and fine. He went and covered the original stop lamp with red foil.
| 08.05.2020 21:08 | # 3 |
[QUOTE = talip206] The minister depends on the person. Normally, they quickly check the lamps and look at it for whatever reason you are, but if you hit one of the hair, it might find another defect again. They left our friend on the examination that the brake lights were burning pink even though they were original and fine. He went and covered the original stop lamp with red foil. [/ QUOTE] you will meet good people from the war, let me see if we change all the bulbs, we will stop again on saturday on saturday.
| 08.05.2020 21:08 | # 4 |
[QUOTE = talip206] The minister depends on the person. Normally, they quickly check the lamps and look at it for whatever reason you are, but if you hit one of the hair, it might find another defect again. They left our friend on the examination that the brake lights were burning pink even though they were original and fine. He went and covered the original stop lamp with red foil. [/ QUOTE] The rear stop was broken. I Paste. I pulled red foil. When you look closely, it is obvious that it is broken. Are they having this problem?
| 08.05.2020 21:08 | # 5 |
Whatever the defect wrote, book them. They just look at the defects.
| 08.05.2020 21:08 | # 6 |
when you repeat the exam, they just look at the fault you have left.
| 08.05.2020 21:08 | # 7 |
Thank you guys
| 08.05.2020 21:08 | # 8 |
[QUOTE = x571] [QUOTE = talip206] The minister depends on the person. Normally, they quickly check the lamps and look at it for whatever reason you are, but if you hit one of the hair, it might find another defect again. They left our friend on the examination that the brake lights were burning pink even though they were original and fine. He went and covered the original stop lamp with red foil. [/ QUOTE] The rear stop was broken. I Paste. I pulled red foil. When you look closely, it is obvious that it is broken. Are they having this problem? [/ QUOTE] It depends on the person doing the control. There was a crack in me, they were glued, they did not cause any problems.
| 08.05.2020 21:08 | # 9 |
Where was the master you took?
| 08.05.2020 21:08 | # 10 |
[QUOTE = Dogukan_3002] Where was the master you took, how much did he handle my brake [/ QUOTE] I went to the master, where I had a general maintenance in the paperhouse, not a braker, two hoses 50 tl 40 tl workmanship, that's all
| 08.05.2020 21:08 | # 11 |
Let's see whether it will be up to date, we will be curious about it here .. I have a similar problem, I have a little time left for 1 month.
| 08.05.2020 21:08 | # 12 |
[QUOTE = Dogukan_3002] Let's see if it will be up to date, we will definitely be curious about it here .. I have a similar problem, I have a little time left for 1 month full inspection again. I'll write right away
| 08.05.2020 21:08 | # 13 |
[QUOTE = Dogukan_3002] Let's see if it will be up to date, we will definitely be curious about it here .. I have a similar problem, I have a little time left for 1 month. the other side had been examined until it passed, and in the meantime, I would like to inform the people who will wear lpg even though the bagel lpg is installed and the filling nozzle is hidden.
| 08.05.2020 21:08 | # 14 |
Get well soon |
| 08.05.2020 21:08 | # 15 |
Get well soon 2 years now
| 08.05.2020 21:08 | # 16 |
[QUOTE = Dogukan_3002] Get well soon, 2 years comfortable now [/ QUOTE] Exactly, I have a comfortable question now. I wonder if there is a time to go to the notary to make it work.
