we couldn't find the solution
08.05.2020 14:54 # 1
atmaca01m
It has been about 1 month since I bought my car, but in the morning and when the engine was cold, the car started very late, but when the engine warms up, it takes in a starter. Does anyone have an idea on this subject, a good master who has worked in the authorized service for 5 years before ..
08.05.2020 14:54 # 2
atmaca01m
Is it possible that the vehicle will be from the 1.4 model petrol injector in 2003?
08.05.2020 14:54 # 3
alicanelka
Try the gas pump.I have encountered the same problem, I had to replace the electric coil, which is solid in the right and left industry, and it is best to consult the authorized service.
08.05.2020 14:54 # 4
atmaca01m
I had the gas pump installed, the master said I measured the output, said good gas, but the imoblizer might not be opening.
08.05.2020 14:54 # 5
atmaca01m
The bar of petrol is dead, 3.5 bar has come and you will understand
08.05.2020 14:54 # 6
Carmania
I think if you want to be concerned with the heat sender, let it be overnight
08.05.2020 14:54 # 7
atmaca01m
we solved the problem, thank you, alicenalka the problem came out of the gas pump, the gas pump we received from the sub-industry, had a bad day.
08.05.2020 14:54 # 8
kizilhakan
Hello, I have received the vehicle for 3 months. There was no problem with the weather, but when the weather gets cold, it runs late for 2-3 seconds.
08.05.2020 14:54 # 9
atmaca01m
If there is a lpg in the vehicle, it may be due to it, or the gas pump will be original. The side industry does not eat.
