we broke the container :( [Problem Determined]
08.05.2020 17:47 # 1
Aziz
Friends say "let me follow me" Countess.
Once the fuse for the ceiling lamp blown. 10 insurance was required, but since it was not there, after 20 tactics, there were 8 or so insurance, one of them had thrown it, it also changed the vehicle, it was not working.
Now the problem is.
Battery lamp stays on when 1 contact is off and clock date center panel stays on
2 central locks do not work
3rd idle 1st line runs and stops at 250 rpm
I am waiting for help from experience owners. Saint 2013-07-12 14:41:51
08.05.2020 17:47 # 2
impact
get well soon..
08.05.2020 17:47 # 3
error
I hope it is a simple problem, but I guess it was 20 instead of 10 that triggered the problems. Confused
08.05.2020 17:47 # 4
BerkeKarayel
brother, insert the correct fuses, which means that by looking at the fuses in the user manual, insert the same ones and reset the pole heads, a car will discharge static electricity in 15 minutes, you have removed the poles, as a result, the lpg settings have been reset by 90 percent.
08.05.2020 17:47 # 5
Alicilik
I think, BSi fuses were burned. If you changed them, you would look at the motor fuses.
If possible, look for errors with a diagnostic. Maybe there is an error at a point we can't see. It can be chassis etc.
As in this screen reset event, it may be useful to try to get the battery off and remove the battery terminal but the healthiest method is to see the errors with the diagnosis.
It is also a little late, but even when I change the bulb, I remove the battery terminal. Vehicle electricity does not come to the beard. One of the BSI and pioneer double I had lit the religion
08.05.2020 17:47 # 6
mahmutbasaran
Master, very well over. I am tall now I hope the container is a small problem ...
08.05.2020 17:47 # 7
Aziz
Thank you very much, I enter through the wire, it is difficult to write, you know.
We improved the idle very much (I am talking about the reason why I am talking :))
This sprinkled some water and at least we solved one problem.
I inserted the idling sensor, made mars, worked with a strange idle, then I put the sensor back on, the mard dynamo has no socket, single cable, I minimized it.
I'm tired by this time, the best forehead, as we say, let's connect to the diagnostics.
The battery lamp is still lit and the clock is on the date panel, I had to insert the + pole and come home
08.05.2020 17:47 # 8
Burak
If there is a shame, it is a shame.
08.05.2020 17:47 # 9
ersin025
I hope it is well done, brother, I hope you can take care of it quickly and easily.
08.05.2020 17:47 # 10
Eternal_Chaos
Sir, get well soon. Hopefully the problems will be solved as soon as possible. Even a tiny thing wears on the head ...
08.05.2020 17:47 # 11
VLKNYKSLN
go directly to PEUGEOT HALDIZLAR ILHAN ABI find me sent RCK with RCZ. Let them do the job.
08.05.2020 17:47 # 12
EmreOz
I think the solution is the only thing I can give an idea of auto electricity ... Smile
08.05.2020 17:47 # 13
Black GTI
My dear, come here today and let me get my auto electrician under my work done.
08.05.2020 17:47 # 14
SDYMZ
if you don't understand my teacher, take it to the tamper master
08.05.2020 17:47 # 15
emre_akdag
Well, Aziz, you made the cry so I hope :( I hope there is no big problem.
08.05.2020 17:47 # 16
Aziz
Emre, you er, John, SDYMZ, ermeöz, eternalchaos, Thank you, the process can not find've done was simple Burak Where mistakes, I looked at all the cable we addition we touch There's nothing that will open bare contact erupted from somewhere else. a lot of misfortune in my job these days,
The point I get angry is why the control doesn't work. What relevance is the lock control with the roof lamp?
08.05.2020 17:47 # 17
umut_25
Don't worry, now you will worry, your mind will always stay in countess and this will wear you further. Ali is right, take it out and get whatever. In this way, you learn why the problem is caused by you. Maybe you did not make a mistake, only an action that you did triggered something else. Once upon a time, a friend of mine used to say that French vehicles do not like electrical additions. Wink
08.05.2020 17:47 # 18
Serkan
Get well Aziz, I think don't worry about yourself any more
08.05.2020 17:47 # 19
ErolSs
Don't worry, it is too late, I hope there is nothing big
08.05.2020 17:47 # 20
soner09
I hope the saint is past, the problem of cozers :(
Page : / 3
