we are on the way
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 19:08 # 1
srknkkc
First of all, hello to everyone. 2 days ago I bought a 1.6 1.6 vti 3008 vehicle. could the indicator be broken? is there any such incident? the petrol light is on and i have traveled max 40km ... thanks for your answers in advance
08.05.2020 19:08 # 2
koray.turan
It is possible to go between 30 and 50 km after the lamp lights up.
08.05.2020 19:08 # 3
talip206
In fact, you should not travel like that, you may burn the gas pump.
08.05.2020 19:08 # 4
BLACK LION
[QUOTE = srknkkc] first hello to everyone. 2 days ago I bought 2010 1.6 vti 3008 vehicle..but when it was going on the road, the petrol indicator stopped from the last time when the car was on the 3rd stop..the trip computer made a low fuel warning ... And I continued. Could the gas gauge be defective? Is there any such thing happening? The gasoline light came on and I have traveled 40km max..thanks for your answers in advance
After the light is on in diesel, I am about 100 km. I can go more. But of course this gasoline can be different. You can only see the range that can be reached with the fuel left on your road computer. The vehicle calculates how long you can go after the light. The main thing is the km in this range. When it is finished there is a blank line (-). That means that the car can stop at any moment at risk. Of course, as soon as the light is on, it is the best and healthiest to get fuel right away.
08.05.2020 19:08 # 5
KILIC
there may be a defect in the display or there is a defect in the sensor in the tank. I guess guys got it wrong
08.05.2020 19:08 # 6
Efe-Pojo
was the 3 lines and the light was on before you traveled 40km without expressing it clearly? Moreover, since the 3rd line from the bottom is inside the red zone, it is normal to light. This is normal if you go 40 km on the 3rd line from the bottom and run out of gas.
08.05.2020 19:08 # 7
BLACK LION
[QUOTE = SWORD] indicator may be defective or the sensor in the tank is defective. I guess guys got it wrong [/ QUOTE]
My friend, you misunderstood Approve . The gentleman lit the light, dropped it to the third line, and 40km above him. He says I'm gone. It's not your diesel, let it go this long range. It is very normal that gasoline runs out and it stays on every road. There is no problem anywhere. You will remove the indicator, the buoy and the tank to the man. LOL We give tactics to be careful again and stay on the road.
BLACK LION 2015-03-06 14:45:03
08.05.2020 19:08 # 8
KILIC
[QUOTE = BLACK LION] There may be a defect in the [QUOTE = SWORD] display or a sensor in the tank. I guess guys got it wrong [/ QUOTE]
You're right I got it wrong. I understood the 3rd line saying the third quotation.
08.05.2020 19:08 # 9
srknkkc
First of all, thank you very much for your interest and your answers.
When I stopped the car, when I turned the ignition to start the starter (of course, I don't think that gasoline was running out), the gas gauge had moved towards the 3rd line.
08.05.2020 19:08 # 10
sezar206
Brother fulle try the tank then it may be the case. Why do you get into 3008 by putting a little gas?
