Water Reduction Problem
08.05.2020 15:41 # 1
marmarascorpion
Hello friends,
My vehicle decreases half a liter of water at 200 km, when I open the hood and check it, I see wetness at the top of the engine, which corresponds to the bottom of the air pipes. When I open and check the water tank, no oil appears on the surface, and when I open the engine cover and check the oil, I do not see any signs of whiteness or water. It does not blow white or any color smoke from exhaust. It doesn't shake when I first start the car.
I do not use the vehicle very much during the week, when I check it, there is no loss or there is no wetness on the engine.
I will take you to the special service for the week. The service will probably call the cylinder head gasket, but I wanted to get some ideas from you before I took it.
the marmarascorpio 2011-06-23 13:57:30
08.05.2020 15:41 # 2
man is missing the cover, change it, it will be fixed. the engine is pressurizing when it is warming up, and it may be on the edge of the cap or in this hose, it is missing. check it
08.05.2020 15:41 # 3
bestfear
yes, it may be missing the cover, but it may also be a problem with your heating system.
08.05.2020 15:41 # 4
There is also a special liquid in relation to it, repairing cracks in the radiator. search
respects
08.05.2020 15:41 # 5
marmarascorpion
Guys, I guess I couldn't describe the wet place exactly, the bottom of the battery coincides,
08.05.2020 15:41 # 6
Okay, if there is no water tank in front of the battery, he may have made a way.
08.05.2020 15:41 # 7
marmarascorpion
Maybe it is 206 too but in my vehicle the battery is on one side, the water tank is on the other side, so when looking from the front, the battery is on the right, the water tank is on the left. In addition, I used stop leak.
08.05.2020 15:41 # 8
I hope that the way of the service has passed to you, I hope there will be no big problems
08.05.2020 15:41 # 9
marmarascorpion
No, the way of service has already appeared, but this problem is not the cylinder head gasket.
08.05.2020 15:41 # 10
You say no water lubrication. isn't it brown?
08.05.2020 15:41 # 11
marmarascorpion
no water stands in its normal color (colorless) :)
08.05.2020 15:41 # 12
It is a big possibility that it is either from the thermostat or it is likely that the hoses going to the thermostat are torn out.
08.05.2020 15:41 # 13
cerci07
You can find the leak under the car, from top to right, from left to inside, after using the car until it warms up a bit, then stop the engine, check the bottom, check the bottom of the water, there is a circulation pump on the right side, check the bottom, check the bottom of the mats. if there is a place you will see
08.05.2020 15:41 # 14
Kemanyak
There is a screw on the iron part to which the thermostat's hose is attached, on the battery side used to remove the air in the vehicle's cooling system. Check that screw. The plastic slot of the thermostat cracks over time, which causes water to flow under pressure. Right next to the battery, this can be counted and the source of the problem.
08.05.2020 15:41 # 15
marmarascorpion
I check the places you said in the evening, write information again, thanks for your answers.
08.05.2020 15:41 # 16
psychoabi
The same problem was with me, even water was missing without making a road. There was one heating pipe at the bottom. I changed it. My problem is solved.
08.05.2020 15:41 # 17
307kirmiziseytan
I had the same problem, I did not have me, you did not know the engine, you did not know what they said.
08.05.2020 15:41 # 18
hhuzun
Check your hoses, maybe you might be missing your throats
08.05.2020 15:41 # 19
revolutionary26
how much water is still the same when i get the car. Not even 1 cm. I almost 3000 km. it worries me. does it evaporate at all, is there no loss?
08.05.2020 15:41 # 20
gocer985
Hello, I have just joined your friends. I HAVE THE SAME PROBLEM IN MY VEHICLE. THE FLOOR BELOW THE DRIVER'S SEAT IS WATERED. CAN YOU HAVE A PROBLEM ABOUT THE HEATER?
Page : / 2
