Water reduction of the vehicle |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 17:30 | # 1 |
| 08.05.2020 17:30 | # 2 |
I don't think it's normal. Do you think it's normal? |
| 08.05.2020 17:30 | # 3 |
Hic is not normal, my teacher immediately gets back and presses again;)
| 08.05.2020 17:30 | # 4 |
I think it's not normal, take it back as soon as possible.
| 08.05.2020 17:30 | # 5 |
Bugra |
Would it be normal, teacher, is my car water running? almost as if the vehicle decreased the same amount of water as gasoline |
| 08.05.2020 17:30 | # 6 |
EErgul |
Would it be normal for the car to drop water :)
| 08.05.2020 17:30 | # 7 |
The radiator is probably pierced. Or it is missing from the hoses. Or from the heater core.
| 08.05.2020 17:30 | # 8 |
The maintenance outlet also fills the radiator water with red liquid, which also destroys vehicles that are not accustomed to antifreeze in this way. The same event is also present in me, maintenance will be 1 year from now, I do not miss any more.
| 08.05.2020 17:30 | # 9 |
the water reduction of the car is not normal, it is not something that will be accepted.
| 08.05.2020 17:30 | # 10 |
If it misses from the hoses, there will be wetness on the ground where the vehicle is located. water is decreasing at the same time, it blows from the hose that goes from the top cover to the air filter ..
| 08.05.2020 17:30 | # 11 |
If it gets out of the hoses, there will be wetness on the ground where the vehicle is located ... There is another problem; the vehicle decreases water at the same time, blowing steam from the hose that goes from the top cover to the air filter ..
| 08.05.2020 17:30 | # 12 |
[QUOTE = EY60] If it gets out of the hoses, there will be wetness on the ground where the vehicle is located ... There is another problem; the vehicle is decreasing water at the same time, steam is blowing from the hose that goes from the top cover to the air filter ..
| 08.05.2020 17:30 | # 13 |
The reason I don't get it is because the masters in the slap don't understand this tool.
