Water reduction
08.05.2020 21:27 # 1
Ferhat5834
Hello to everyone. My vehicle is running out of water all the time. Now that the water is getting low, I went to the mechanic and said he was missing from the bottom plug of the starter, and I made it the next day. There is something like a bidet. The tank is filled to the brim and sometimes even more water leaks out of the lid. Some said it was a gasket or something, but there was never a loss of oil, white smoke, or traction in the car. I'm waiting for your help
08.05.2020 21:27 # 2
Kemal2344
My brother, I had the same problem, don't get any money from anyone. Your thermostat is gone, so we looked.
08.05.2020 21:27 # 3
Ferhat5834
God bless you this is the answer I want from you. Thank you.
08.05.2020 21:27 # 4
Ferhat5834
You said 400 pounds, but now I looked at thermostat prices 90 100 pounds something
08.05.2020 21:27 # 5
Nurettin46
Whatever relevance thermostat my brother has, the car will either heat up or it will not get hotter. I think from the ground
08.05.2020 21:27 # 6
Ferhat5834
it is confused. Anyway, I will go to the repair shop today and check it out.
08.05.2020 21:27 # 7
Kemal2344
my brother thermostat is constantly circulating the water in the tank, I had the same problem, the thermostat has a spring under it, the nail is broken without overheating for many years. After installing LPG, the vehicle stops at the gas station, the cycle stops and stops at the railroad station. Help me, God, I will burn the car.
08.05.2020 21:27 # 8
Ferhat5834
You said that the cycle is constantly traveling. If you try to clean the throat butterfly and adapt it, the head will get better.
08.05.2020 21:27 # 9
Ferhat5834
Meanwhile my water auction still continues. When the engine warms up, it carries a reserve tank.
08.05.2020 21:27 # 10
74emre
If you call 0537 877 22 73 hours 10, I will tell you in detail the same problem and solution that I had.
08.05.2020 21:27 # 11
Ferhat5834
OK, I saved your chief number, I will send a message and we will talk when it is available.
08.05.2020 21:27 # 12
babamert26
My teacher has been going through the same problem for 1 year in my vehicle.
08.05.2020 21:27 # 13
Ferhat5834
I am suspending from the reserve water tank and its cover. I'll change next week. Because it stays loose, it carries water from the lid due to germination.
08.05.2020 21:27 # 14
babamert26
Can you write your ferhat teacher number, I want to contact you
08.05.2020 21:27 # 15
Ferhat5834
For those who are curious about the solution. All my efforts were in vain, I changed the reserve tank, it improved
