Water reduction
08.05.2020 19:40 # 1
blntctn
Hello friends again,
Although I changed the vehicle, I am responsible for the malfunctions because I could not send the vehicle to my father :)
I ran the car yesterday morning, I said I would look at the water or something, I took the antifreeze from the 3-liter oil, I took the antifreeze from the opposite oil. lightly fallen sewye, under the vehicle, look at the top, nothing, drip, nothing, I looked at the engine oil, there is no increase in the level of the oil, there is no increase in the level of oil, there is nothing visible in the oil, where this water may have gone.
The last was missing water from the heater, I had it built on the driver's side, I looked at it, and I didn't see it.
08.05.2020 19:40 # 2
The cover of the reserve water tank never changed :)
08.05.2020 19:40 # 3
blntctn
What is the replacement water tank cap?
08.05.2020 19:40 # 4
the cover of the tank where we add water
https://www.peugeotturkiye.com/peugeot-206-radyator-kapagi-orjinal
sonerkyl 2016-02-24 09:34:30
08.05.2020 19:40 # 5
blntctn
no brother never changed
08.05.2020 19:40 # 6
it may be defective. I think if it continues, there is a problem with the engine, then try a cheap piece like 15-20 TL. Let's see if it will continue.
08.05.2020 19:40 # 7
blntctn
Let me change, let's see, brother war is something else that may be a problem that comes to your mind
08.05.2020 19:40 # 8
Well, if you say I checked my mind, I did not see the leak, there may be a problem with the engine. radiator hoses, thermostat socket etc. It should be observed
08.05.2020 19:40 # 9
akk0212
Check the pipes may be loosened or cracked, I think only so much water will not escape from the cover in a short time, if there is lpg, it will also make it from the pipes.
08.05.2020 19:40 # 10
IbRahiM_quRcaN
Firstly, get well soon . Is there any wetness in the radiator honeycomb, brother?
08.05.2020 19:40 # 11
blntctn
I think that there will be a wetness under the car, at least if it is in the pipes, it is not less if it goes on the engine.
08.05.2020 19:40 # 12
Cyrus35
* It can escape from the radiator cap.
* It can escape from heating hoses from connection points. Even if you don't mind, it may be filling the car's chassis * under the interior trim.
there may be a crack in the engine block (trouble we never want. not to think badly)
* There may be holes in the radiator while the vehicle is traveling, it may be beating with pressure as the water gets hot.
* If it is overheated and the gasket is lit, it may be leaking. (That water is already steam from the engine block temperature and you can not find where it flies & where it flows.)
SOLUTION: The vehicle will be really interested, you will go to a mechanic who you think will not deceive you, be suspended and operated in that way, and check the places where there is a possibility of leakage by hand and eye. Trial and error is not a situation to be done, it is important to find out where it is going from where there is a serious leak. Thumbs Up
08.05.2020 19:40 # 13
blntctn
my teacher explained very well, by the way, the water is running out before the car is running, it is definitely decreasing when it is running.
08.05.2020 19:40 # 14
usta307
If my brother car is cold, the hoses are lpg, check the hoses entering the brain, because the water is used in the summer months, the heated water is polluting. said we found it from there usta307 2016-02-24 14:56:35
08.05.2020 19:40 # 15
red 206
Sa friends, the same problem has been with me for two weeks. I was parked the car when one evening was coming, I looked at the car, I looked at it in the morning. I finished the water, I went the road, the heat hurts, the fan hurts at 97. I pulled the car. I stayed with the pliers in the tank in the gasket inside the lid. I'll let you know when I find the problem.
08.05.2020 19:40 # 16
Cyrus35
You will open the hood of your friends vehicle and check everywhere. If there is nothing visible, it will be suspended and looked after.
08.05.2020 19:40 # 17
talip206
I think it is flowing into the vehicle, look at the heating connections again, sir. The interesting thing is that the vehicle is running out of water. It is necessary to see the leak from a certain place. Spread a newspaper under it and wait.
I don't think it will be from the lid because it throws it out in the form of steam. For this, the vehicle has to start and heat the water so that it can be thrown out as steam. talip206 2016-02-24 21:13:30
08.05.2020 19:40 # 18
blntctn
Although it was reduced yesterday when I was cold, I had left the car without starting since yesterday, there is nothing underneath it.
08.05.2020 19:40 # 19
srdrgktp
Hello friends ;
You know the 1,4 tdci fiesta and 206 engines with the same old cases. It happened to us in the fiesta and in my 206 vehicles. There is a collector style piece that distributes the water in the motor. In 206 and fiesta diesel engines, you will see a fine humidity when you look at it with a flashlight between the battery and the air filter if the problem is there. A plastic casting piece around 80 100 tl. And I say why do your luck here.
Yours sincerely, everyone.
08.05.2020 19:40 # 20
blntctn
Let's go to the master tonight and show him what will come out
Page : / 2
