water reduction
08.05.2020 19:10 # 1
mtok61
I could not find the reason for the loss of water in my vehicle, I showed it to the master.
08.05.2020 19:10 # 2
mtok61
I'll be crazy or travel in the car with a milet suit bag
08.05.2020 19:10 # 3
pusutr
Is your car overheating?
Don't let the water leak from somewhere ..
08.05.2020 19:10 # 4
Mesut48
Is there any wetness in the mat? If it is only on the driver's side, replace the gasket of the heating pipe,
Only the gasket, not the honeycomb.
08.05.2020 19:10 # 5
E.B
If the floor mats are not light, check your radiator.
08.05.2020 19:10 # 6
mtok61
There is no normal wetness or radiator.
08.05.2020 19:10 # 7
muhammed.ceyhan
There is press printing in the middle of the reserve water tank. If there is air in the vehicle, that press can open the pressure. it leaks very thinly. look at him. And look at the hose at the bottom inlet of the reserve water tank. is there any wetness? look there too. he may be missing from there. the hose can become loose over time. If the problem is in the places I mentioned, you need to bleed the vehicle's cooling water system.
finally pull the dipstick. will you see water on the stick? I hope you won't see. if there is water, the gasket may be burned.
08.05.2020 19:10 # 8
themurat54
Did your car come from lpg, mine was due to the hose that goes to the lpg brain, the places where the antifreeze sheep flows will be better at least themurat54 2015-03-24 16:50:50
08.05.2020 19:10 # 9
mtok61
When the cold was cold on the floor, yesterday we changed the plastic yesterday.
08.05.2020 19:10 # 10
naimkaya
my brother had the same problem from the radio :) every time I started the car I was putting 2, 5 liters of water: D
