Water radiator water leak
08.05.2020 16:52 # 1
xpyhre
Hi, I opened a topic about horn. I took the horn, put the car with the help of a jack to reach the horn. Now from the upper plastic of the radiator, there is a crack-like crack as thin as KIL. but it does not leak water, only when the radiator hose is tightened by hand, very little water is missing. Would I miss water when I started the car? the tool is not working right now I'm waiting for a piece. & nbsp; 404 steel adhesives do my job, they use radiator leaks, I would appreciate if you help like a kind of green gum .. xpyhre 2012-06-21 22:26:09
08.05.2020 16:52 # 2
toga406
because of pressure and temperature, you have a problem when the car is stolen.
08.05.2020 16:52 # 3
xpyhre
There is a previously applied piece I do not know if you believe it is bonded with a green glue on the radiator, but it sticks like iron. I'm a solid mix of 404. You mix the yellow and green two. You apply it to the leaking place, freezing like concrete after 30 minutes. It's not 404, like normal water. In addition, it does not miss the hose, I circulated with the hose, I hand tightened it from the top, there is a small leak in the plastic parts of the radiator in the plastic parts.
