Water problem in 307 luggage
08.05.2020 20:06 # 1
ben_erhan
friends,
I reviewed the forum. I think the problem of getting water in the trunk in the 307s is from chronic mistakes.
but the problem with me is a bit mild.
If my vehicle is uphill, it does not get water in the trunk. if parked downhill take water ..
but there is no excessive water intake.
When you lift the luggage carpet and look at the light around the spare wheel, there are a lot of shiny wetness.
I can add pictures for friends who don't look in the eyes.
I am waiting for an answer from my friends who have an idea for a solution.
thanks.
08.05.2020 20:06 # 2
If you examine this issue, you will solve the water intake problem. & nbsp;
http://forum.peugeotturkey.com/forum_posts.asp?TID=43407&title=arka-tamponu-sokup- water-removal-kun will
08.05.2020 20:06 # 3
ben_erhan
Mine is for sure. I have read this topic. Friends wrote that the parts in the ventilation rot. I looked with light and looked clean. I touched it with my hand and there was wetness in my hand. Thanks behind the stops etc.
thanks
08.05.2020 20:06 # 4
talip206
There are two possibilities, one is the ventilation grill under the bumper and the other is the rear stops. 307s take water from these two places
08.05.2020 20:06 # 5
ben_erhan
I will look at both. I hope I will solve
08.05.2020 20:06 # 6
Peugeot35
[QUOTE = ben_erhan] Is mine sure too? I have read this topic. Friends wrote that the parts in the ventilation rot. I looked with light and looked clean. I touched it with my hand and there was wetness in my hand. Thanks behind the stops etc. [/ QUOTE]
The wicks in the aeration were solid in me, but they take the water from the plastic. When you look through the trunk, the ventilation eyes are visible, normally it is dusty there. It is also useful to remove the water stops from the stops and check the gasket.
08.05.2020 20:06 # 7
ben_erhan
It is necessary to pour a lot of water from the edge of the stops and observe while the trunk is open.
If he does not get out of there, he is taking it from the exact ventilation ...
I am very unhappy in such matters. The problem that no one finds me finds. I hope it is one of two regions
08.05.2020 20:06 # 8
GokhaN
If the tires that meet the trunk lid have torn holes, etc., they may leak from there, maybe it is necessary to observe completely, as their friends say
08.05.2020 20:06 # 9
ben_erhan
Friends, is there a master or know who can do in Istanbul regarding the problem of water intake.I am currently in Istanbul.10.15 fün burım ..
Good forums
08.05.2020 20:06 # 10
Orcun.Dmr
There are 2 possibilities. It either takes it from the gasket of the stops or takes it from the luggage ventilation. If you take a picture of where the water is and throw it away, I can answer you clearly. & Nbsp; "Smile"
08.05.2020 20:06 # 11
hzr206
I have a bodybuilder, I can direct it if you want, but I do not know if it has made such a repair
08.05.2020 20:06 # 12
ben_erhan
Where is my brother? I'm in Bahçelievler. Pejo307 will remove the bumper, make silicone to the rear grilles and put the bumper back on.
If it is familiar and close here, can you call and ask.
08.05.2020 20:06 # 13
ben_erhan
[QUOTE = 307 1.4 hdi] There are 2 possibilities. It either takes it from the gasket of the stops or takes it from the luggage ventilation. If you take a picture of where the water is and throw it away, I can clearly answer you. "Smile" [/ QUOTE]
A little below and right in the middle of the trunk lock I think it enters from the point .. I entered the trunk myself, one of your friends kept the water, never entered ... but when we look at it once a month, there is always water in the trunk ... I dry it. It happens again. during the trip, he knocks under the car through the grills .. nothing else comes to mind ben_erhan 2017-07-24 23:57:56
08.05.2020 20:06 # 14
ben_erhan
Friends, we removed the rear bumper .. we looked at the air vents on the back. They are not going to get water. They were very strong and dry. A day ago, flooded Istanbul. Despite there was no sign of wetness, we also siliconized and closed it. Also, let me look at the spare wheel, there was dry, the car never took water under the rain.
08.05.2020 20:06 # 15
Peugeot35
[QUOTE = ben_erhan] Guys we removed the rear bumper .. we looked at the air vents in the back. They are not going to get water. They were very strong and dry. One day ago, Istanbul flooded. Despite there was no sign of wetness. We also siliconized and closed it. Also, let me look at the spare wheel, there was dry dry .. The car did not get any water under the rain. / QUOTE]
< font face = "Arial, Helvetica, sans-serif" size = "3"> If you have siliconized the ventilation we are talking about, try the following.
1- If there is an opening in the rear window, it will disappear.
2- Takes the headlight stops.
3- Suppositories.
4- Leak through the mechanism where we opened the baggage There is rebellion.
5- It can receive from the antenna. < / b>
there are no more places to check out these counts.
08.05.2020 20:06 # 16
ben_erhan
Okay brother, I'll take care of it all ... thank you.
rear window or roving frame is high
