water on the battery
08.05.2020 19:03 # 1
SDYMZ
water is coming from the windshield to the battery. How can I prevent this?
08.05.2020 19:03 # 2
SDYMZ
08.05.2020 19:03 # 3
themurat54
The same came to me from the side of the battery, the water was down. There is an auto electrician in this problem, removing the plastic in front of the ten windows, and the medicine or something is sticky. I was filled with water inside the electronic brain of the gas.
08.05.2020 19:03 # 4
SDYMZ
no more, I will squeeze black silicone into the place where the glass and the black part meet.
08.05.2020 19:03 # 5
Eric Cartman
The drain hole at the end of the windshield seems to be clogged, overflowing water is flowing into the engine compartment. Can you check that the evacuation is open.
08.05.2020 19:03 # 6
SDYMZ
[QUOTE = Eric Cartman] The drain hole on the end of the windshield seems to be clogged, overflowing water flowing into the engine compartment. Can you check that the evacuation is open. [/ QUOTE]
I checked the clear water is going through the channels but some of it is leaking between the glass and the black piece
