Water loss problem in Reserve Water Tank
08.05.2020 19:19 # 1
TugyyStyle
My car 206, 2008 model 1.4 engine comfort model. I have noticed that the water has decreased in the spare water tank of the vehicle since I bought the vehicle for a long time.
08.05.2020 19:19 # 2
berk2309
look under the rust on the side of the sip
08.05.2020 19:19 # 3
TugyyStyle
Sir, I have never seen wetness like that.
08.05.2020 19:19 # 4
TugyyStyle
actual
08.05.2020 19:19 # 5
talip206
If there is wetness under the driver's side mat, he misses the heater core. But if not, check the hoses on the engine. If there is a lpg, they say some reduction is normal. Up to half lt every 2 months. But if this rate is higher, you should definitely have bigger problems in the provinces.
08.05.2020 19:19 # 6
TugyyStyle
The Atiker lpg may be missing on the cover of the Water tank in the current vehicle. Is there a leak in a light cover? there is no such a reduction. Close to 2 liters between 1-2 months.
08.05.2020 19:19 # 7
talip206
If there is no lubrication in water and abnormal oil, replace the cap and try. If there is lubrication in the water or situations such as foaming in the oil, the gasket may be missing. It is most likely from the cover, but
08.05.2020 19:19 # 8
TugyyStyle
It seems to me that it seems more logical to change that water tank completely :)
08.05.2020 19:19 # 9
bozlak
Brother brother check the radiator pipes on the engine. It may be a leak. It happened to me. The car was constantly dropping the water. and found the leak, the problem was solved when the water leaking from the pipe dripped onto the hot engine and replaced the evaporated pipe.
08.05.2020 19:19 # 10
oguzhan53
There was no leak anywhere in my vehicle, including the heating pads, I was looking for. one of my friends may have lost the cap feature, he said it is set to 1.4 bar.
08.05.2020 19:19 # 11
peugeot murat
1.4 HDi mi vehicle
08.05.2020 19:19 # 12
TugyyStyle
My teacher used the car yesterday yesterday, the car warmed up with a lot of lpg in the city but the car did not do anything, and it came to my mind that when I looked at it, water came as if it were leaking. so the amount of course decreased with the effect of the heat but I think from the cover :)
08.05.2020 19:19 # 13
peugeot murat
It comes from the joints of the radiator cap or lpgnin t pipes.
