Water Level Sender 206 1.4 hdi
08.12.2020 08:57 # 1
206rchdi
Hello friends, my vehicle entered a little space, the level fault light was lighting, I changed the level indicator, it does not light the fault light yet in the morning, the moment I start the first starter, the lights go out when I turn on the lights and when I press the brake, I add a little bit today to see if the water is missing. I will try it in the evening, do you think he did it because he was missing water or what happened to him?
08.12.2020 09:03 # 2
Hello, teacher. probably because the water level was lacking. on the warehouse max. It will be enough to add water until its level is reached.
08.12.2020 09:21 # 3
206rchdi
I added Mr. Soner, yes, it was below the max level.
08.12.2020 09:24 # 4
It's not normal that it triggers it, sir. He's probably doing chasis somewhere. It can be in contactlessness in the socket or caboos.
08.12.2020 09:31 # 5
206rchdi
It doesn't do it because of lack of water.
