Water leaking on the clutch [resolved]
08.05.2020 20:46 # 1
x571
In strong rain and when I hold strong and abundant water on the grill where the wipers are, the water from the clutch leaks about as much as the bottom of the tea glass and wet the mat. why does this happen? Where should I check? grills are clean.
water comes from where I pointed. The marked place is just above the clutch under the steering wheel.
I looked at the ground with black grille, it's clean. I looked through his ranges, I couldn't see an evacuation channel. where should i look?
x571 2018-03-09 13:49:54
08.05.2020 20:46 # 2
RP393
First, check the glass wick in the left corner. Also, there should be a drain hole in the black groove in front of the glass. It can become clogged over time.
08.05.2020 20:46 # 3
x571
topic updated! pictures added. understanding friends are expected to help.
08.05.2020 20:46 # 4
KILIC
An external action was taken on your vehicle. Such as sound system, fog light etc. If done, check where their cables run. the hood openings mandala
08.05.2020 20:46 # 5
x571
[QUOTE = KILIÇ] Your car was externally processed. Such as sound system, fog light etc. If done, check where their cables run. there is a hood opener mandala [/ QUOTE]
No action was taken. As far as I understand it is made of pressurized water. It doesn't rain. It started to be one to one.
08.05.2020 20:46 # 6
most likely there are places with cable crossings coming to the engine compartment from there, my teacher. You have to take a good look
08.05.2020 20:46 # 7
x571
[QUOTE = sonerkyl] it is most likely that there are places where there are cable crossings coming to the engine compartment from there, my teacher. You have to take a good look [/ QUOTE]
Will the black perforated panel with the wipers come from there? Is there a place we should look at that panel? What should I look for in the cable entries? how is the water leak. Need to look for a huge hole Smile
08.05.2020 20:46 # 8
ggitaristt
Look at the clutch wire and harness entrance, my teacher, the insulation of the places is not good. Normally, there is no water.
08.05.2020 20:46 # 9
x571
Thanks to those who helped solve the event. This morning I washed the car and opened the hood. There was a drain hole in the section where the bonnet joints entered, and that hole was filled with leaves over time. hard to see, scabies. The hole was filled with water. I pushed with a long thin stick, found the hole and opened it. It went down on the leaves blocking the drain hole. there is no problem now. Fortunately I looked and found it myself. There was even a problem with glass.
08.05.2020 20:46 # 10
RP393
I said it in my first message. It is necessary to check it occasionally. Glad to be resolved. Good evening.
08.05.2020 20:46 # 11
x571
[QUOTE = RP393] I said it in my first message. It is necessary to check it occasionally. Glad to have it resolved. Good evening. [/ QUOTE]
Yeah. In a very opposite place, I didn't know there was such a thing;)
