Water leak emergency situation filled with water
08.05.2020 18:09 # 1
MertMurat
Hello friends before I snowed, I put a red antifreeze on my car and then the car started to decrease water. On the same day, I noticed that there was no water in the du tank and I put about 2 liters of water. The temperature was rising to 100. I looked at the water, there was no water again, I put 2 liters again, I finished it again. More than 1.5 liters of water are leaking. How can we solve it, can I do it myself or should we take it to a master.
08.05.2020 18:09 # 2
tigerland
Go to the service and replace it from felt or gasket, I think 30 tl or something.
08.05.2020 18:09 # 3
MertMurat
Thank you, I hope he is not missing from other places.
08.05.2020 18:09 # 4
Serkan
You can browse the link below.
08.05.2020 18:09 # 5
rizeli_53
it seems that it can be done if such works are available. I think your brother serkan mail is very revealing. Get well soon
08.05.2020 18:09 # 6
elsoberano
I had the same problem, it was 40 liras, but you can solve it by using the link it gives to the brain while asking much cheaper.
08.05.2020 18:09 # 7
I am afraid of the answer I will get, but I wonder why 407 water is decreasing and where is the heating core in 407
08.05.2020 18:09 # 8
MertMurat
I was thinking of doing it myself, but my left thumb just left the hand, they sewed it from 2 to 3 o'clock, and now I will take it to the service.
While opening the can, the lid of the can was cut between the hand and the thumb. There is a cut of about 5 cm. It did not damage the tendons. 2 doctors were able to sew in 1 hour
08.05.2020 18:09 # 9
fxmen
the same problem happened to me in the past year, it was all over the years after the antifreeze was put.
08.05.2020 18:09 # 10
samet206
The heater core problem is known. If you live in Istanbul why did you need to put red antifreeze, you can get rid of a price between 30-50 TL anyway, if you want a change in heating honeycomb, you can get a 250 TL or something.
08.05.2020 18:09 # 11
All of these problems are due to the fact that summer anti-freeze coolant is not used in vehicles since the beginning.
08.05.2020 18:09 # 12
kuscu38
[QUOTE = koliva] All of these problems are because the summer anti-freeze coolant is not used in vehicles since the beginning.
Just like that, when you put antifreeze, a world emerges. LOLLOLLOL
08.05.2020 18:09 # 13
[QUOTE = kuscu38] [QUOTE = koliva] All of these problems are due to the fact that summer anti-freeze coolant is not used in vehicles since the beginning.
When used with water only for a certain period of time without antifreeze, it corrodes its pipes and channels in the engine. The place where the radiator core explodes is where the resources are generally. It finds its weakest point, due to its antifreeze cleaning feature, it removes rust, but this time it also explodes because it takes rust from rotting spots.
08.05.2020 18:09 # 14
MertMurat
Istanbul is where I am but I saw it at night -7 in Kemerburgaz, so I felt it was necessary to put antifreeze.
08.05.2020 18:09 # 15
metin
[QUOTE = MertMurat] is located in Istanbul but I saw it at night -7 in Kemerburgaz.
antifreeze must be placed strictly. You can handle this problem with a karering gasket, but when you do not put an antifreeze, the engine block may crack with cold water.
08.05.2020 18:09 # 16
Ssedo
We had the same problem, we had red antiviriz and it started to flow after that :) but in general, we have a problem.
08.05.2020 18:09 # 17
okan77
you will not be upset about the things that can be done with money, you will not be stuck ... get a great history ...
08.05.2020 18:09 # 18
MertMurat
What exactly is the name of this seal?
08.05.2020 18:09 # 19
ahmed206
they call it ring or karering, but if you say directly, they don't know where karering is. I hope they will replace the seal of the radiator inside and tighten it well. Mine improved like that.
