Water is entering the vehicle.
08.05.2020 15:06 # 1
betermen
Hello there,
I have 307 SW. After it rains, water enters the vehicle. (The mat on the driver's side gets wet.)
Anyone faced with such a problem? Why is it caused? I would be glad if anyone knows how much it costs.
08.05.2020 15:06 # 2
klemann
Hodja, pull the vehicle to the channel, look under it. I don't think it's bruised but maybe you've hit somewhere. Certainly there is a hole
08.05.2020 15:06 # 3
xdesign
if the vehicle is drilled afterwards (sound system, exhaust valve, neon, etc.) to pull any installation from the outside, it may be in the drilled place. I had an example in my f7R. Or, as your friend says, it may be drilled due to the blow. It's a difficult thing, but it's one of the big possibilities. Then a sheet of metal will be pulled from the bottom and welded. 20 30 TL is something maximum.
08.05.2020 15:06 # 4
I had the same problem. The chronic peugeot problem said master. He said that the interior of the door will be removed and glued again. I didn't believe it :) I still had it dismantled. There is a kind of coating material on the inside of the door, I don't know its name, it's a foam-like plastic material right now. That coating disappears over time from where it is glued, in fact, when it rains, the water comes to the inside of the door.This material allows the water to go to the channels on the sides of the door, but when it loses its feature, it leaks to the bottom. I saw with my eyes, I believed. The leak comes from there. It is very difficult to find a master who knows his job well. He held water with a hose, from where he called the glass, the water leaks towards the driver's doorway. He lifted it there and glued it again. The problem has been fixed. Have a look at a body shop. the cover 2011-02-18 18:36:11
08.05.2020 15:06 # 5
kaanalp
THE SAME PROBLEM I HAVE ALSO..DOWN THE DRIVER COMPARTMENT IS WATER FILLING A DAY EVERYTHING WAS CLEANED YAMGUR FALAN FROM THE WINDOW DID ANY MORE?
08.05.2020 15:06 # 6
kaanalp
HOW MUCH COSTED FROM MY FRIEND WHAT
08.05.2020 15:06 # 7
UGuRs
I don't know if you have it in your vehicles, but my 206 also has plugs at the bottom, if there are a few in your vehicles, it is probably there.
08.05.2020 15:06 # 8
betermen
I showed the vehicle to a few places in Umraniye auto industry today. Finally, I found a competent master of his job. (Hasan master-Birlik oto) Leaked the smell and taste of the water and said he was antifreeze. The 307s have a rectangular caliper core (50TL). As it is not durable, its plastic deforms over time and flows and leaks antifreeze to the driver's or front passenger's side. Workmanship for torpedo removal is 100TL. so it will cost about 150 in total. The car needs to stay in service for 1 day.
The other 2 places I showed did not understand that the water was antifreeze and asked for 200TL to remove the torpedo.
worse financing 2011-02-19 10:34:42
08.05.2020 15:06 # 9
betermen
If it was in dry weather, antifreeze may have flowed in yours. Look at your scent. If it is caused by antifreeze, I think show it to a master without waiting too long.
08.05.2020 15:06 # 10
betermen
[QUOTE = kaanalp] THE SAME PROBLEM I HAVE ALSO .. I DID THE DRIVER COMPARTMENT UNDER WATER FILLING A DAY EVERYTHING WAS I CLEAN YAMGUR FALAN FROM THE WINDOW? / quote]
08.05.2020 15:06 # 11
kaanalp
I put antifreeze in my car 2 months ago ... but this problem has happened before and it is still repeating ... so A. I DON'T THINK THAT IT IS FROM THE OVER ... BUT THANKS TO YOUR KNOWLEDGE :) :)
08.05.2020 15:06 # 12
formulaone
my friends, this problem is very simple, don't worry about it, this is a problem and I am writing it as a solution, there is a cover under the gear box, there is a door with two screws on the right leg speed of the sofor seat, there is a calor heater core of 30 cm. the only thing is to change the honeycomb, you do not need to leave the vehicle in service for 1 day. There is no other solution, 99 percent of it, this situation
08.05.2020 15:06 # 13
Yusuf Tekoglu
[QUOTE = betermen] I showed the vehicle to several places in the auto industry in Umraniye today. Finally, I found a competent master of his job. (Hasan master-Birlik oto) Leaked the smell and taste of the water and said he was antifreeze. The 307s have a rectangular caliper core (50TL). As it is not durable, its plastic deforms over time and flows and leaks antifreeze to the driver's or front passenger's side. Workmanship for torpedo removal is 100TL. so it will cost about 150 in total. The car needs to stay in service for 1 day.
I Have The Same Problem With Me.
08.05.2020 15:06 # 14
selcuk-307
[QUOTE = formulaone] my friends, this problem is very simple, don't worry about it, this is a problem and I am writing it as a solution, under the gear box, there is a cover with a screw with a right leg speed of the sofor seat, there is a honeycomb, there is a honeycomb, there is a boiler of 30 cm. the only thing you need to do directly to the mop is to change the honeycomb, and you do not need to leave the vehicle in service for 1 day. your solution to be refilled later this is no other solution. 99 percent of it is this situation [/ QUOTE]
well explained, I congratulate our friend. The masters who say that the chest should be removed know very well that the chest does not need to be removed. But if he does the other job in half an hour, he cannot demand 200 TL. so they resort to this fraud.
only 2 screws will be unscrewed, and the hand makes it easy. honeycomb will be removed, be careful while removing the honeycomb, some of the antifreeze will be emptied into the vehicle. antifreeze will be added after the new honeycomb is installed. 50-60 TL honeycomb. 20-30 TL workmanship. 10TL antifiriz.Total around 100TL
selcuk-307 2011-02-19 14:27:58
08.05.2020 15:06 # 15
bayrakmt
Hi friends,
I just joined here, we recently bought a 206 sw hdi - 2004 model pejo.
We completely overhauled the car.
this topic discussed caught my attention. Because the same problem we have in 206 I realized today. The floor of the driver's mat is wet, and even because the car is tilted to that side (from where I parked) 1-2 cm towards the corner. I noticed a deposit. When looking at the water, it is not difficult to understand that there is radiator water directly, because the water in the same reservoir was the same as the color (dirty yellow) and it was obvious that it was slightly oily, that is, antifreeze.
Judging by the writings of the friends, the radiator will change, then isn't it?
Called on the right under the gearbox, does this also apply to 206?
Otherwise, torpedo removal or something ... I have never heard of in any car. I hope this job will not cost us much ...
08.05.2020 15:06 # 16
ataks
My 307 had the same problem on Saturday, the master took care of it in 1 hour without removing the chest.
08.05.2020 15:06 # 17
formulaone
[QUOTE = selcuk-307] [QUOTE = formulaone] my friends, I am solving this problem very hard, don't worry about it, this is the problem and I am writing it as a solution, there is a cover with two screws at the right leg speed under the gearbox and a 30 cm calorine pad there. There is no need for you to change the honey when the honeycomb fails and it goes straight to the mop and also to change the honeycomb. your car will be emptied while doing this process, your solution will be refilled later, this is no other solution. 99 percent of it is this situation [/ QUOTE]
my friends explained this issue and i love my 307 vehicle very much and these vehicles are really good compared to the other vehicles that we use, they are very comfortable and they are worn with the carpet in time with the suspension. If you buy a honeycomb in the boiling heat, it is not that cheap, but it is a quality without quality. But this is a kind of honey, it's a bit of a kind of beer, ask your master, and according to him, you brought your honey and then don't waste time. I mean, I want to inform you about it.
08.05.2020 15:06 # 18
betermen
[QUOTE = my flag] hi guys,
First of all, my teacher. I have 307 SW. I changed the heating core last Saturday.
There is no need to insert the hood for the shifting master 307, but 206 and partners had to push it in.
a disgusting water was filled into the vehicle. When changing, the other water left in the pipes drained inside. I took the sponges out and washed them. It smells like carrion.
vacuum in auto washers does not work. Because he can't undermine my file. it is impossible to dry in this air. you have to insert the floor.
as price
removing the hood: 100TL
radiator: 50 TL
antifreeze: 20 TL
Trying to clean the antifreeze water under the mat for 3 days is invaluable :)))
the most damn thing is to dry the water. the cables go through the bottom, I don't know what the cable is but the damage gorurse costs him.
If this happens to me, the first thing I will do is go directly to the authorized service. As soon as the key is delivered, you can clean it up, dry, clean. Give more than 100 lira.
08.05.2020 15:06 # 19
selcuk-307
Get well soon. the master we spoke to took care of? Did you go to someone else?
08.05.2020 15:06 # 20
tkavalli
INTRODUCING WATER IN 307 S CHRONIC DISEASE. THE HEATER OF THE HEATER HAS BEEN OPENED OR THE DRIVER PART IS TAKEN WATER UNDER THE MAT. GASKET 1 TL FOR RADIATOR UNLOADING 19 TL COOLING WATER FLUID BY GIVING 20 TL.
Page : / 3
