Water is dripping from the car's roof lamp.
08.05.2020 16:06 # 1
ekinoks44
Hello friends .. When it rains too much or sometimes washes from the ceiling lamp on the front of my car, water drips do not always happen, but when it happens, it is oil drip like water :). It hasn't happened before, it has started to happen now. There is an antenna on that part, does water leak from the intermediate parts of the antenna? What should I do for that part? I would be glad if you could help.
08.05.2020 16:06 # 2
samett53
I took the silicone on the edges and remove the antenna.
08.05.2020 16:06 # 3
34sea45
[QUOTE = samett53] I lived at the edge of the strip to remove the antenna :) [/ QUOTE]
+1 Thumbs Up
08.05.2020 16:06 # 4
sahin-peugeot
Replace the bottom of the antenna, the part that stepped on the body has lost its feature, not expensive, something between 10-15.
08.05.2020 16:06 # 5
ekinoks44
Well, if I find it then, I change the bottom and I do not get silicon. Thanks for the answers.
08.05.2020 16:06 # 6
metin
The antenna of the 206 is not at the back? otherwise I did not understand my sunroofs in the back.
08.05.2020 16:06 # 7
ekinoks44
not in the back, but in the front, in the sunroofs.
08.05.2020 16:06 # 8
metin
[QUOTE = equinox44] can be not in the back but in the front, in the sunroofs in the back. [/ QUOTE]
I thought it might be taking it from the windshield, thinking it was at the back, but the antenna was leaking from the sides of the antenna at the front. Do it as soon as possible because if the water has reached the level to enter, if the floor has absorbed the water, the floor will begin to sag after a while, and the ceiling sheet will start to rust.
08.05.2020 16:06 # 9
HAR_teo
[QUOTE = text] 206's antenna isn't behind? otherwise I did not understand my sunroofs in the back. [/ QUOTE]
antenna with panoramic ceiling and sunroof at the back and others at the front Göz Kırpma
08.05.2020 16:06 # 10
mehmet eren
get over, my friend is a crazy situation
08.05.2020 16:06 # 11
tolga35
Get well, my brother; I can offer you a solution like this: request an auto tire from the palm like a palm (auto inner tube) free.Remove the antenna base and cut the float like a gasket as much as the points pressed by the antenna bottom, then make two layers if necessary. The rubber pieces that you cut meat prevent the entrance of water like a gasket and it does not attract attention when viewed from the outside.
08.05.2020 16:06 # 12
sifremi unuttum
If there is sunroof, wipe-clean the rubber gaskets thoroughly, dust-mud etc. under them. to remain
08.05.2020 16:06 # 13
sedataksu
+10000
08.05.2020 16:06 # 14
only_younus
If the roof is flowing, you should draw logs :)
joking aside you can do a clean job with silicone
08.05.2020 16:06 # 15
I Love My Pug
A friend of my citroen saxo was doing the same, give my brother from the bottom of the antenna 15 TL.
08.05.2020 16:06 # 16
mehmet1965
wow, like a joke or myself, 106 did the same in 206 and it would be easy to get it fixed.
08.05.2020 16:06 # 17
ismail ozdemir
I have 307d the same problem is dropping in the rain very much, but it happened 2 times in 2 years.
