Water is dripping from the Accelerator Pedal.
08.05.2020 16:55 # 1
pug206
friends, water is dripping from the car's air conditioner compartment inside the vehicle. I don't understand why it is slowly. div> is there a blockage in one place or something when it turns on the air conditioner because ....
In the picture, water leaks from the place indicated by the arrow and pours in the place that I marked with a round place ,, the carpet there flowing down from something like flex.
08.05.2020 16:55 # 2
Serkan
If the air conditioner is on, it is the steam made by the air conditioner, but I have no idea how to cut it :(
Serco05 2012-07-25 18:38:45
08.05.2020 16:55 # 3
pug206
I will open it and look at it, but unfortunately I can't do it.
08.05.2020 16:55 # 4
zgr
Antifreeze was put on my vehicle last winter after a long break. I think the rust in the antifreeze pipes has removed the lime and I guess the water flowed from the place you showed until the morning the mat was soaking wet. but the air conditioner was off. Today, the air conditioner was turned on, after a while, I turned off the air conditioner and waited inside the vehicle. the ventilation grilles were moistened or even water was dropping from place to place. I think mine is due to hot weather.
08.05.2020 16:55 # 5
tigerland
gasket variable 30 TL or more & nbsp;
08.05.2020 16:55 # 6
Check the inside of the area under the wipers. Leaf, dust, soil may be out of the way. & Nbsp;
08.05.2020 16:55 # 7
pug206
koliva master I will take care of your warnings and look at that partition and clean it tomorrow. 5 drops or something.
08.05.2020 16:55 # 8
metin
[QUOTE = koliva] Check the inside of the area under the wipers. Leaf, dust, soil may be out of the way. & Nbsp; [/ QUOTE]
my brother feels like water from the karering at the chiller heater connection (:
< a href = "http://forum.peugeotturkey.com/forum_posts.asp?TID=20250&PN=1&title=soutma-suyuinin-aracn-%DDine-szmas-problemi" rel = "nofollow"> http: / /forum.peugeotturkey.com/forum_posts.asp?TID=20250&PN=1&title=soutma-suyu-aracn-%DDine-szmas-problemi
08.05.2020 16:55 # 9
[QUOTE = text] [QUOTE = koliva] Check the inside of the area under the wipers. Leaf, dust, soil may be out of the way. & Nbsp; [/ QUOTE]
Text came to my mind, but I thought that water would come from there if it came from there.
08.05.2020 16:55 # 10
tigerland
I think there are pieces in the link given by koliva. I guess it was too oring, or if there is another piece it has changed, & nbsp; show it to the private service, I think. & nbsp; tigerland 2012-07-26 11:12:23
08.05.2020 16:55 # 11
metin
[QUOTE = koliva] [QUOTE = text] [QUOTE = koliva] Check the inside of the area under the wipers. Leaf, dust, soil may be out of the way. & Nbsp; [/ QUOTE]
Text came to my mind, but I thought that water would come from there if it came from. Can the pedal come to the top? Then you drop it?
There is not any kind of water because there is a leak from the engine compartment, it cannot flow there.There is something in the gasket style between the engine and the interior of the part you see in the picture at the end of the pipe ( gray spongy part between the two black pipes ). I don't think it will come in and flow even if there is a leak I think this problem is the karering problem that meets every 206 and 307
08.05.2020 16:55 # 12
The text is right in that regard, but if it boils above the grid, it can come from the top. The worst case is, if the plastic cover of the gas pedal is removed and examined by hand, it is understood where the water came from. Especially in the part of the heating core, there is already water.
08.05.2020 16:55 # 13
metin
[QUOTE = koliva] You're right about the text, but if it bounces above the grid, it may come from the top. The worst case is, if the plastic cover of the gas pedal is removed and examined by hand, it is understood where the water came from. Especially in the part of the heating core, there is already water.
I understand it.
08.05.2020 16:55 # 14
nurinuri58
I did not read who wrote what but. I HAVE THE SAME PROBLEM I HAVE A SOLUTION. & Nbsp; If the brother goes to the master, the heater will break out and change. To replace the 100 TL honeycomb and honeycomb, it is necessary to remove the front chest completely 150 TL. don't do that. There is a gasket at the junction called orling on the gas pad & nbsp; 1tl let them replace it. Let's say that the heater core is bursting, do not disassemble the breast, go to somebody who knows the job, you do not need to remove the breast when the heater core pulls from the gas pedal & nbsp;. Get well soon.
08.05.2020 16:55 # 15
pug206
the leak comes from the gas pedal, it flows from the hadith, not even a drop like that ... I would have lost my
cell phone connection cable, if I hadn't lost it, I would take a photo of it here.
08.05.2020 16:55 # 16
nurinuri58
Yes, as I said, the two pipes have a connection between each other, there is a ring-shaped gasket. those two pipes are loosened a little by the 3 screws with bolts.
08.05.2020 16:55 # 17
[QUOTE = pug206] the leak is coming from the side of the gas pedal flowing from the hadith is not even a drop like this ... I would have lost my
cell phone connection cable, if I didn't lose it, I would share the photo here. .
Let's get you started then "LOL" < br> http://forum.peugeotturkey.com/forum_posts.asp?tıd=20250&pn=1&title=soutma-suyunun-aracn-%ddine-szmas-proble my Reviews
