Water in the front seat mat
08.05.2020 19:43 # 1
suleyman123
Hello friends, there is water under the front seat cover, sometimes I look at it, my uncle is running out of water.
08.05.2020 19:43 # 2
baya1994
A problem that happens to everyone is on the right side of the accelerator pedal from this heater core. It's coming from there. You need to change the o-rings, print on the net, even shared here
08.05.2020 19:43 # 3
suleyman123
Thank you, brother, thank you.
08.05.2020 19:43 # 4
ozgorh
Yes, I had the same problem, very slightly, there was a honeycomb blocking substance, a powder master, put it in the coolant, if not too much, you can save a leak.
08.05.2020 19:43 # 5
cihan_ch
If it is not very much, I would try the obstructor and I had the same problem. I changed it by changing the honeycomb, but if the leak was not very useful, I would change the workmanship to 120 TL.
08.05.2020 19:43 # 6
palet
It is useful to examine the subject.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=12974&pıd=183674#183674
