Water in Air Filter
08.05.2020 20:47 # 1
cod0key
Hello everyone. My vehicle 206 1.4 X-line. Due to the low traction of my vehicle in the past days, I checked the air filter and realized that it was soaked. I immediately removed the filter, jacked up the car and looked at the bottom air filter box.
I noticed that part 11 in this scheme was missing and somehow the rainwater entered the part 10 with its mouth open, causing low traction etc. You will say take part 11, but part 11 does not have the possibility to get stuck because there is a lower plate of the headlight of the car just above the open. I am waiting for your suggestions and comments thanks
08.05.2020 20:47 # 2
RP393
If it were me, I would use it in the way it would take off after the 6th part. Both the water does not enter and the vehicle relaxes.
I am very pleased with the 45 degree pvc elbow and the open filter attached to it after the 71 no mark in my vehicle.
08.05.2020 20:47 # 3
cod0key
Well, teacher, this piece 10 is probably there to slow the air flow. I wonder if I get off after 6
08.05.2020 20:47 # 4
RP393
[QUOTE = cod0key] Okay, this track number 10 probably exists to slow the air flow. I wonder if I get off after 6 [/ QUOTE]
As I said, me and many many people use it this way. The longer the line is, the more power consumed for air suction increases. Performance drops.
08.05.2020 20:47 # 5
cod0key
Okay, teacher, thank you very much for the information. I will sting tomorrow Smile
08.05.2020 20:47 # 6
HasGur
[QUOTE = cod0key] If I subtract after 6, will there be any problem [/ QUOTE]
Whatever is involved in the air, which has to obey the law of gravity, is pulled by your engine before it reaches the ground, while a large part continues to clog the air filter, small particles reach the combustion chamber.
FRIENDS ...
To reduce costs, manufacturers make sure to produce manual controls, even the rear windows that the consumer faces many times every day, and they do not use a single unnecessary screw under the hood!
It will be the most appropriate action to obtain and replace the missing part.
Part code 14264H
ADDITIONAL: ALSO WHICH ARE USING 10 NUMBER OF WHICH ARE HAPPENED, MAY CALL "AIR INTAKE RESONATOR ".
Hasgör 2018-03-04 14:34:34
08.05.2020 20:47 # 7
cod0key
Wouldn't it work if I bought a piece of non-zero product? I wonder. I am a student now, it may be troublesome to provide zero parts.
08.05.2020 20:47 # 8
RP393
[QUOTE = cod0key] Doesn't it work if I bought a piece of non-zero product? I wonder. I am a student now, it can be troublesome to supply zero parts. [/ QUOTE]
My brother, Ali Bey, thanks to the scientific part of the work. The air resonator absorbs the sound of the suction air just like the exhaust muffler. It only reduces engine suction noise. Meanwhile, it is the power spent. I told you your practice and ease. You can use what I say without any problem. The zero of that piece is not immediately found in the second hand. Do what I say. Dry your filter in the room heat for now, and change it at the first opportunity.
In the picture you can see where my filter is attached.
RP393 2018-03-04 18:54:43
08.05.2020 20:47 # 9
HasGur
Although it has an important duty to provide clean and cold air to the engine, you can get that piece of plastic simple pipe, 20,30 lira, and the price of the new one is around 70 lira.
08.05.2020 20:47 # 10
HasGur
[QUOTE = RP393]
FALSE !
You cancel the resonator and use that filter to pay more for less fuel and do little damage to the engine! For engine in factory design While air intake is provided at the cleanest possible place at outdoor temperature, it has been used to cool the radiator that reaches 90 degrees and it can be used for block, cylinder head etc. You have allowed the engine to suck overheated air due to the surrounding hot parts!
As a general opinion, the task of the resonator is only to decrease the volume, but none of those who have this opinion will ask themselves why the sound increases in the suction line!
SEE FOR DETAILED INFORMATION: https://itstillruns.com/air-intake-resonator-do-12156112.html
08.05.2020 20:47 # 11
KayaMotors
FALSE !
My interest in the vehicles is more than necessary and I do it by loving it. You have been very successful in telling the event with its reality deeply and I congratulate you seriously and I agree with what you say. Peugeot 307 2006 1.6 1.6V I want to wash the Resonator completely in my gasoline car (due to the dust and dirt accumulated in it) Do you think it is a master. ClapClapClap
