WATER FROM WHITE SMOKE AND EXHAUST
08.05.2020 14:05 # 1
206volkanist207
slm friends
My car had a slight sound of noise this morning without starting the engine,
stopped 1-2 km after driving, I ran it again, white smoke and water came from the exhaust, and then when the road went on the road, the car got stuck all the time. I wouldn't eat a pile in the service
I'm waiting for your help
08.05.2020 14:05 # 2
haruncoskun
If the car is LPG, it is normal to get water from the exhaust at the first start, but the sound of water is not a good sign during start-up.
08.05.2020 14:05 # 3
206volkanist207
thank you mate vehicle 206 1.4 xr gasoline
engine presumption I guess?
08.05.2020 14:05 # 4
haruncoskun
[QUOTE = 206volkanist207] thank you mate vehicle 206 1.4 xr gasoline
engine presumption will be right? br>
08.05.2020 14:05 # 5
hasimayaz
we have to measure and look at the compressor. it is highly probable that the gasket is burned.
08.05.2020 14:05 # 6
206volkanist207
Mr. Hashim yesterday they looked at the car, they checked the inside of the water container, they said the gasket was not burned, they could not see any abnormality in the engine.
08.05.2020 14:05 # 7
haruncoskun
[QUOTE = 206volkanist207] Hasim yesterday looked at the car checked the inside of the water container, they said the gasket was not burned, could not see an abnormality in the engine.
Do not lower the gasoline below the quarter tank, I think you can damage the pump as well as pull the dirt out of the tank and seriously damage the engine.
08.05.2020 14:05 # 8
206volkanist207
IF THE FRIENDS HAVE PROBLEM SOLVED, THE AIR FILTER WAS GIRLED, WAS INSERTED INTO THE FILTER OF THE FILTER, IF I DID NOT RISE BY VEHICLE IN THE RAIN AIR
08.05.2020 14:05 # 9
SelmanBeber
Come on, your eyes are bright. this time you ripped without much expense :)
08.05.2020 14:05 # 10
206volkanist207
Thanks, man, I am still surprised how the water got into the air filter.
The air pipe is sucking from the bottom. I did not enter the puddle.
08.05.2020 14:05 # 11
ErkanKurnaz
get well cheap you teared walla
