Water entering the 307 trunk |
| 08.05.2020 17:21 | # 1 |
| 08.05.2020 17:21 | # 2 |
maestro |
The rear wiper water hose comes inside the taillight, it is drilled. Unscrew the nuts from inside the stop lamp and see the hose, stick the hole part. There is no logic of siliconing from the outside. Water accumulates inside and poured from the bricks again.
| 08.05.2020 17:21 | # 3 |
What I say is only when it rains but master, but I got the master to make him look at him
| 08.05.2020 17:21 | # 4 |
fatihgg |
Is the water filled or happening in the bolus where the spare tire is located?
| 08.05.2020 17:21 | # 5 |
First, make sure that the water enters from there. Grab water with a hose and try. Reviews
| 08.05.2020 17:21 | # 6 |
No, my teacher is just water on the back of the left taillight like pocket
| 08.05.2020 17:21 | # 7 |
fexzi |
as if the same topic existed in the forum
| 08.05.2020 17:21 | # 8 |
I couldn't see it, master, if you found it, maybe it was there, maybe it was found there.
| 08.05.2020 17:21 | # 9 |
xMEGANx |
It enters through the Vent inside the rear bumper, not the taillight. Remove the bumper and tighten the black silicone around the 2 vents and the problem is 100% solved. it is not an important problem or even a problem. something caused by the wear of those plastics. If you want to give 150 TL and get zero, the problem is removed from the service :) get past;)
| 08.05.2020 17:21 | # 10 |
Well, I am in a state of scabies because my car should be without problems.
| 08.05.2020 17:21 | # 11 |
They have written the solution here & nbsp; I have it too, I couldn't do it yet :) I couldn't do it :) -water-Substituted-zM div>
| 08.05.2020 17:21 | # 12 |
I showed the master today, from the top, he came from the ground, could not detect it completely, I was in a hurry because the ceiling did not get wet, but I did not understand the water coming from above.
| 08.05.2020 17:21 | # 13 |
Well, if I miss this problem, if I get it to the service place, can they solve it?
