Water Decreases
08.05.2020 20:39 # 1
Ferdiosman27
Hi guys, I have a peugeot 2008 model 1.4 comfort sedan petrol-lpg car. Water comes in from the top of the accelerator right side. At the same time, the car reduces water. I took it to İslahiye. The man said that the heater core is a hole, put an obstructive medicine, and water did not come in 20 days. Recently, water is coming from there and decreasing. What should I do in the winter. Thanks in advance ..
08.05.2020 20:39 # 2
ggitaristt
Do not add that kind of stuff to your sister engine, oil or water.
You control the heating radiator, it may be missing the radiator. It may be missing from the connections, or water may enter the pipes from outside.
You have to see the leak with your eyes first .. You have to open up there and look ..
08.05.2020 20:39 # 3
OguzhanKucuk61
The same problem happened to me in time. One morning I found my car with Petek erupted into a lake. Chest was removed and radiator replacement was done. The problem continues. There is an amount of leakage that I can call dampening from where you say, from that part of the gas pedal. I know the solution is oring, but I haven't gotten it yet.
08.05.2020 20:39 # 4
my teacher is taking away from the orings. related topic
