Water coming into the battery under the wipers
08.05.2020 21:27 # 1
helwasteak`s chef
Water comes to the battery under the wipers.
Does anyone have a short practical solution suggestion ..
A friend who happened to solve the problem
Is there anyone who can help?
Depending on the car, there was a starting problem even when the battery was dried in water, the starter was difficult to press.
I cleaned the pole (-) pole rust, but it is not a complete solution.
helwasteak`s chef 2020-02-10 17:02:03
08.05.2020 21:27 # 2
The reason for this is that there are parts under the bakelites (plastic part) under the front wipers of the teacher, because the ratio of the ratio does not fit properly, the water comes to the battery. There are friends who stick and seal with silicone. There will be topics in the forum. welded from parts 5 and 6 in the link
08.05.2020 21:27 # 3
kaan206
[QUOTE = sonerkyl] this is because my teacher has parts under the bakelites (the plastic part) under the front wipers, the water comes to the battery due to the incomplete rate. There are friends who stick and seal with silicone. There will be topics in the forum. welded from parts 5 and 6 in the link
Just like you said, there are 3 clips that fix the plastic and it drops it from the clips.
I removed the plastic floor, put the dayson silicone on the clips and reassembled it.
I looked at it again dripping again, this time I drove it through the motor on the clip ends, dripping was stopped.
But instead, if the clip with gasket is taken and made, it will be more original.
