Water Auction
08.05.2020 16:37 # 1
YUNNES37
friends before, there was air in my car's radiator, thermostat, circulation, timing changed.
& nbsp;
now there is no air problem but & nbsp; the vehicle decreases water. & nbsp; & nbsp; the temperature rises up to 90 but then it falls. There is no problem with the vehicle going. no water comes out of the exhaust. the oil looks normal and the water does not appear foaming.
I wonder why. I couldn't observe a leak in a place that burned my seal
08.05.2020 16:37 # 2
by_nefretimsin
08.05.2020 16:37 # 3
by_nefretimsin
the gasket from the top cap is probably gone
08.05.2020 16:37 # 4
psychoabi
check the radiator hoses, look at the clamps
08.05.2020 16:37 # 5
mucahidyasar34
My brother, you probably burned the cylinder head gasket. Look at the radiator open water, if the oil is mixed, the seal is burnt
08.05.2020 16:37 # 6
YUNNES37
The water in the radiator is normal and the oil is normal. It seems to me that the gasket is burnt. I'll have a few questions.
second, how can I understand otherwise, the burning of the gasket?
08.05.2020 16:37 # 7
mucahidyasar34
The engine was not the same problem, it was in me. Check your exhaust, press the gas, let someone close your hand with the exhaust. If you have already burned the water. If the cover does not go to the test, it goes to the grinding, then it goes back to the test, and you also give the gasket money. Take it to the master you want, it does not give you a price below 600. None of them have been newly built. We have 9 cars in our company for 7 years, so I made it very convenient.
08.05.2020 16:37 # 8
gabriel
Brother if there is no oil in the radiator water. There could be cracks in the radiator. I took it to me in a few places. They cost 300-500 liras. I searched from the internet. I used radiator crack inhibitor. There is no shortage in 1 week. Thank God ... I suggest you try it. Without expense.
08.05.2020 16:37 # 9
YUNNES37
I hope so, my hope is that way
no oil in the water, no water in the oil, not exhausting water from the exhaust
& nbsp;
or I couldn't detect it.
08.05.2020 16:37 # 10
cerci07
There is a place in the ground, I can recommend you to recycle the pipes and repeat the bottom of the mats.
08.05.2020 16:37 # 11
Doesn't the dripping of water from the exhaust come from the health of the engine. I know that steam and water are normal especially in cold weather. Can we understand the burning of the gasket by looking at the exhaust?
08.05.2020 16:37 # 12
mucahidyasar34
Check my friend's radiator. Is there hot water running through all the pipes?
08.05.2020 16:37 # 13
YUNNES37
ok brother i hope so I will write the result here
08.05.2020 16:37 # 14
mucahidyasar34
call me last care. 0531 501 86 14 all kinds of help
08.05.2020 16:37 # 15
YUNNES37
thank you thanks & nbsp; i saved your number
