Water Auction
08.05.2020 15:59 # 1
The car did not go out for a week, but I ran it every day, warmed it, cooled it ... 45 km I came yesterday, I came out from work in the evening, gave a warning while going home, stopped, went out, stopped, stopped, opened, looked at the water, was missing. How did he diminish as much as two fingers?
08.05.2020 15:59 # 2
[QUOTE = ezelefe] look at the engine, there is water at the bottom of the battery, if there is water, it is running away from the thermostane .
It happened to me too ... Of course, there may be holes etc. in the Radiator.
08.05.2020 15:59 # 3
Let's see if something happens from the gasket.
08.05.2020 15:59 # 4
Take It To A Master You Know Take It On The Lift ... They Are Pressing The Water Channels With A Machine Like A Compressor ... The Leak Appears In 1 Minute ...
08.05.2020 15:59 # 5
I can take it to Monday, if I check it at the earliest, I can not go for two days. But warning from Allah that the car water is running low.
08.05.2020 15:59 # 6
[QUOTE = ezelefe] stop the car wait for 3-4 minutes then thermostat if it is running out of the water from below.
Don't forget your arm, Colonel, I'm still waiting for you PM)))
[/ QUOTE] Brother I Have Not Been To Accessories Yet I Have A Little Job ... So I Will Go To The Latest 1 Hour Gülme the albaydemirc 2011-08-13 09:54:14
08.05.2020 15:59 # 7
As I said there is no kidnapping, it can be done normally but if it leaks from the heating system
08.05.2020 15:59 # 8
metin
You can hardly tell if hüseyin is leaking from the engine because as the water is hot, you can see it evaporate as it leaks, and it does not remain like oil.
08.05.2020 15:59 # 9
I will go, I will look at it, they will change unnecessary things, now we need to find a good master in vain.
08.05.2020 15:59 # 10
[QUOTE = ezelefe] If you have time, you can push it to the side of the sponsor sponsor murat.
+100 Very Good Idea ... I Carried All Maintenance Of My Vehicle There ... Bide Şahin-Peugeot Murat Abi Immediately Adjacent ... You Won't Regret It ...
08.05.2020 15:59 # 11
I will go, it will not be open tomorrow one day a week.
08.05.2020 15:59 # 12
kaan__
can also leak from the cylinder head gasket
08.05.2020 15:59 # 13
I'm afraid of it, the seal is long work
08.05.2020 15:59 # 14
kaan__
open the hood, look at it, you will see if you look carefully kaan__ 2011-08-13 16:45:53
08.05.2020 15:59 # 15
Look at the water, if the radiator water is brown and oily, the gasket has burned. water is already reducing in such cases
However, if there is no such situation, look at the radiator cap and it leaks because it is not completely closed. if the room is in order, there is a hole crack in the radiator
08.05.2020 15:59 # 16
Bavik
look under the front seat right and left mats, if there is moisture or water, water may be leaking from the calcareous radio
