WATER AND OIL LEAK
08.05.2020 15:00 # 1
metin
Friends first greet everyone. My name is Metin, I agree with you from Istanbul Pendik. 2004 I have a Peugeot 307 BVA (Devil Red). First of all, I am very pleased that I just bought my car, but there were a few expenses, we got it fixed. I recently noticed that there was a water leak in the engine and then there was an oil leak. I could not show it to the services because I had the tube installed on the vehicle, I showed it to the special services, they told me that it was missing oil from the eccentric seals and that the gasket between the engine body had to change water. I just changed the trigeri then there was no oil, then I wonder if it happened. I showed you my distress in detail on a representative painter. I would like to take advantage of your vast experience, to receive your comments and suggestions on whether the diagnosis and solution are correct, and to get good expert advice that will save me from this job in the Anatolian side of Istanbul. Best regards...
08.05.2020 15:00 # 2
ismail ozdemir
I have the same problem with me. Did you manage to solve the problem?
08.05.2020 15:00 # 3
is my text no? When did it happen?
08.05.2020 15:00 # 4
masumserseri
In my opinion, at least the cost of the guess would be 1000 TL. If the oil leak too much and the vehicle does not decrease the oil, do not reach the bottom.
08.05.2020 15:00 # 5
Is the subject hosed?
08.05.2020 15:00 # 6
so much :))
08.05.2020 15:00 # 7
metin
[QUOTE = cecoli] is my text no? when did you tell me that you never said this ... [/ QUOTE]
Bro, thank God there was no problem.
I changed the timing in one of your dishonesty, the next day the car started to miss the oil the next day, I went back to the same man, said the eccentric seals and the cylinder head gasket would not be lower than 400 tl, I was suspicious, I said I would investigate, I asked a few places, they said the same things, the eccentric seals and gaskets would change.
Anyway, my research solved the problem, I found the harun master, thanks.
Problem: Loosened the "oil drain plug" underneath the dishonored eccentric seals that changed the triger, and when the oil began to leak, he tried to stab me, saying he was escaping from the eccentric,
Harun master tightened the oil drain plug and the clamp of the so hose coming from the radiator, no problem (:
May Allah be pleased with him, and God should do as He knows in this dishonest.
(THERE IS A REPRESENTATION OF PICTURE, I HAVE FINDED FROM THE INTERNET TO EXPLAIN THE PROBLEM)
text 2011-03-25 10:47:16
08.05.2020 15:00 # 8
metin
[QUOTE = beyazzzzz] I have the same problem with me. Did you solve the problem of the natal? [/ QUOTE]
What is your problem? Do you write in detail and what is the kilometer? . I had some experience on this subject, maybe I can help.
08.05.2020 15:00 # 9
masumserseri
Anyway, you can get over it cheap. You have to fill your breasts with no honor.
Where exactly is the "oil drain plug" under the camshaft seals.There is a similar problem with my friend, but his vehicle 206 1.4 diesel.
the masumserser 2011-03-25 11:04:22
08.05.2020 15:00 # 10
metin
[QUOTE = masumserser of]
I don't know diesel, but the petrol 1.6 engine 307 oil drain plug is an allen bolt in the region I marked with yellow on the far left in the painter. you will understand immediately.
