Wasting 306 Gas Wasted
08.05.2020 14:56 # 1
sfyucedag
When I increase the gas in my vehicle while my friends are on the road, the speed drops again after finding the empty 5, as if the clutch was pressed, then the vehicle reacts and is affected by the gas.
My vehicle 2001 306 XR Platinium.
There is not much tremor while idling. The vehicle is LPG and I experience this problem both in LPG and gasoline.
I said idle engine, I said let me ask, I would be glad if I get the answer as soon as possible.
08.05.2020 14:56 # 2
EK-6
Clutch pressure is missing the lining. Nothing else.
08.05.2020 14:56 # 3
yaramasyaramas
I think the pressure is on the pad.
08.05.2020 14:56 # 4
I agree with what friends say. If there is this much stripping, the vehicle may not be deformed. It has nothing to do with the idle valve since it is in the transmission of trouble. There is no problem with the idle valve if the vehicle is running smoothly at the idle, does not stop when it releases gas, does not stop at gear changes or when it comes to the boot ...
08.05.2020 14:56 # 5
sfyucedag
Thank you guys, thank you very much, I will go to the industry tomorrow, I will stop on the printing pad. I hope it will be solved.
08.05.2020 14:56 # 6
Come on let's see :)
08.05.2020 14:56 # 7
sfyucedag
As you said, I changed the printing pad, the problem is over, the problem of the vehicle has changed perfectly. I bought the original piece for 180TL (set).
