Wasted in 5th gear?
08.05.2020 14:02 # 1
HakanGokdemir
Gears are wasted when we shift into 5th gear.
Where do you think the problem might be caused by, thanks in advance for your help ...
My guess would be clutch pressure-lining even if it is probably synchromesh or low probability?
Vehicle: 1997 model Toyota Corolla
hakan1203 2009-03-02 17:35:30
08.05.2020 14:02 # 2
Ismail
This is what happens when the reverse gear is shifting in us: s but leaves the drain and enters full pressure
08.05.2020 14:02 # 3
hasimayaz
[QUOTE = hakan1203]
90% synchromesh hakan .. but the gearbox is this closed box .. When it is opened, everything must be prepared.
08.05.2020 14:02 # 4
haruncoskun
[QUOTE = hasimayaz] [QUOTE = hakan1203]
I agree with Haşim, the problem seems to be synchromesh, but after the gearbox is opened, it may come up in other things.
08.05.2020 14:02 # 5
HakanGokdemir
Thanks guys, as you said yes, the closed box is just synchromesh.
08.05.2020 14:02 # 6
holzma25
I have the same problem 1-2-3-4. There is no problem with the gears .. but when we go to 5, there is a voice called garçç. sometimes it does not pass, but after a while it is wasted. Disapprove
08.05.2020 14:02 # 7
TOLGA
years ago, I had the same problem, I had to change the complete transmission,
I hope the owner of the vehicle is not as unlucky as me,
08.05.2020 14:02 # 8
oguzhan29
synchromesh made of
08.05.2020 14:02 # 9
EK-6
The synchromesh gear will not be wasted. Only the transition is very difficult and the gear can be damaged.
The fault here is the 5th gear gear is broken. Most likely the group response is broken.
If you come to atatürk sanai site, I can make it and deliver it on the same day.
