warning sound?
08.05.2020 15:27 # 1
friends tonight I noticed that there was nothing in the car while there was a beep. The beep that normally sounds when the doors are opened or when the petrol light is on is on the road, and it beeps once. There is no warning. There is no case visible on the indicator! do you think this is a messenger of something? I do not understand? I would appreciate if you help.
respects
08.05.2020 15:27 # 2
Could Hydraulic Oil Be Missing For example When Climbing Uphill or Downhill
08.05.2020 15:27 # 3
Yeah I did it when I went up the ramp, I came a long way. But I did not understand what he did when he was going straight between the neighborhood. does my hydraulic oil? I just put it on the steering fluid, so I guess it won't be a couple of months.
08.05.2020 15:27 # 4
You are right, it does not subtract immediately ...
08.05.2020 15:27 # 5
thanks. I will look at him, but I am thinking why he can do it. there is sound no text Wall
08.05.2020 15:27 # 6
Well, nothing comes to my mind ...
If the fuel decreases, the hand brake stays above, if the door stays open, there is none of that.
I Sams Wacko
I Can't Believe Something Seriously The Greatest Chance Hydraulic Oil ... Lack
08.05.2020 15:27 # 7
Yes, I checked all the things that I am on the road. doors closed parking brake low fuel normal but nothing visible Ouch
08.05.2020 15:27 # 8
goktug
Does it do it when it starts to accelerate first ... in 1st and 2nd gear?
08.05.2020 15:27 # 9
beveta
if there is a problem in the front arrangement of rot, ball joint, swing, rot head axle etc ...
08.05.2020 15:27 # 10
black_rock
10 to 15 seconds after moving, I hear this voice but not very often by the way !!!
08.05.2020 15:27 # 11
ose
[QUOTE = beveta] if there is a problem in the front arrangement of rot, rotil.wing swing rot head axle, etc ... it will sound in this too ... [/ QUOTE]
let's do it too
08.05.2020 15:27 # 12
beveta
[QUOTE = kankam_743] [QUOTE = beveta] if there is a problem in the front arrangement of rot, ball joint.
Come on, is he doing it too? [/ QUOTE]
08.05.2020 15:27 # 13
beveta
There is no warning on the screen, but it will be interrupted after 2 times the other times die and repeats this action from time to time ...
08.05.2020 15:27 # 14
[QUOTE = pugti] friends tonight I noticed that the car is beeping when nothing is in the car. The beep that normally sounds when the doors are opened or when the petrol light is on is on the road, and it beeps once. There is no warning. There is no case visible on the indicator! do you think this is a messenger of something? I do not understand? I would appreciate if you help.
respects
Tape made of.
08.05.2020 15:27 # 15
ose
[QUOTE = beveta] [QUOTE = kankam_743] [QUOTE = beveta] rot, ball joint. Swing rod axle etc ...
Come on, is he doing it too? [/ QUOTE] [/ QUOTE]
I disagree because there is no voice over there.
08.05.2020 15:27 # 16
ose
All you have to do is check your transmission oil level
08.05.2020 15:27 # 17
There is an electronic mechanism sensor in the very interesting ball joint roles.
I just started to hear new things Göz Kırpma
08.05.2020 15:27 # 18
[QUOTE = göktuğ] does it when it starts to accelerate first ... in 1st and 2nd gear? [/ QUOTE]
I start the vehicle 1st or 2nd gear does not matter. Beep once in 5th gear. it is not continuous but occasionally chirps.
08.05.2020 15:27 # 19
[QUOTE = mustiii] [QUOTE = pugti] friends noticed tonight, the car is beeping when there is nothing. The beep that normally sounds when the doors are opened or when the petrol light is on is on the road, and it beeps once. There is no warning. There is no case visible on the indicator! do you think this is a messenger of something? I do not understand? I would appreciate if you help.
respects
Tape made of.
The tape was not original, I wore another one, and until this time, it did not give any warning.
08.05.2020 15:27 # 20
ose
Did you look at the sanjiman? oil to
Page : / 2
