warning sound !!
08.05.2020 18:02 # 1
foresteng.
Hi friends,
Yesterday and the day before, there is a warning sound whenever I turn the ignition of the car. There is no extra lamp on the indicators and there is no text on the screen. There is gas, the temperature is normal, the doors are closed.
Anyone faced with such a situation ??
08.05.2020 18:02 # 2
I am going to say that there may be a problem in the indicator lights, but our cars also write on the screen if there is a situation that will light the indicator lights. If any options are automatic and hungry, it will also be written on the screen. Does the sound contact come through or the pressure on marsa?
08.05.2020 18:02 # 3
foresteng.
when the ignition is on, it sounds once or twice and then there is no sound.
08.05.2020 18:02 # 4
If there is no sound, no image, I think it is necessary to connect the car to the computer. But I hope it's not an important thing. It is one of the small electronic problems of Peugeot.
08.05.2020 18:02 # 5
Serkan
Try replacing the control battery, if it hasn't changed recently.
08.05.2020 18:02 # 6
Burak
I understood that the lamp was lit on the screen which lamp is on if I do not misunderstand.
08.05.2020 18:02 # 7
foresteng.
[QUOTE = Burak] I understand that the lamp is lit on the screen which lamp is on if I do not misunderstand.
no lamp is on and the text does not come out .. I went to 3 different places on Sunday, so I started 3 times .. Just gave the same sound at the 2nd time but again there is no phrase, very strange and annoying !!!
08.05.2020 18:02 # 8
Serkan
Sir, this is an experience tool, not from the remote control, manually lock from the door locks, then open it manually again and turn the ignition.
08.05.2020 18:02 # 9
mrtoknctn
I have it in my car .. my auto headlight sensor is on because it is on, so if your car has a headlight sensor or rain sensor on it, it may be warning
08.05.2020 18:02 # 10
foresteng.
Well, it is always on, what does it mean for those sensors to be automatic after turning it off? How can it be turned off, for example, when the headlight sensor is already in the park position at zero position, does the sensor turn off .. or not?
08.05.2020 18:02 # 11
zerzevat
Probably not the warning sound coming because the gas light is on ?? I said to write it in case it is overlooked.
08.05.2020 18:02 # 12
foresteng.
[QUOTE = vegetables] Probably not the warning sound coming because the gas light is on ?? I said let me write it in case it is overlooked. [/ QUOTE]
yo not yo ...
08.05.2020 18:02 # 13
pusutr
I know that the car beeps 1-2 times for warning purposes when it passes the key when the control battery is weak.
08.05.2020 18:02 # 14
foresteng.
[QUOTE = pusutr] I know that the car beeps 1-2 times for warning purposes when it passes the key when the control battery is weak.
Ok .. Nothing else is left anyway ..
