Warning light and oil selection for 2012 308 model
08.05.2020 21:22 # 1
Merthinho
hello everyone I have a 2012 Peugeot 308 1.6 vti ov model car. It's been a short time since I bought the vehicle. I will have maintenance at the beginning of next month, but yesterday evening, the car signaled a warning in the triangle. The oil level also appeared on the information screen. The industry is closed as it coincides with Sunday. We did not know what to do We put 1 lt 20/50 thinned oil. We hope that it will handle 3 to 4 days.
I know the subject I'm wondering is not doing well but will it take me to care?
Does this warning mean anything else?
Thank you in advance for your help.
08.05.2020 21:22 # 2
omerb
First of all, your vehicle is good. I hope you use it without trouble and trouble.
Did you check the oil level when you gave an oil error?
According to him, did you say that oil is missing and you added oil?
Also by 5-30 recommended for most of your engine I had heard of a little oil reduction problem of Vti engines.
There are labels on the vehicles that say oil change times after maintenance. Do you have it? Which oil has been used before.
Oil is a serious material, for the engine.
08.05.2020 21:22 # 3
Merthinho
thank you for your good wishes. We have added oil by paying attention to the user manual and warning.
The person we bought had said that he was doing maintenance about 10 thousand km ago, and I developed a little by thinking that you would manage. Unfortunately, there is no label from previous maintenance, but I will note this as much as possible. My first vehicle and it came to my very inexperience. Obviously I added oil and I regret it.
I will make no more than 10 km until Tuesday, and I will have it maintained soon.
08.05.2020 21:22 # 4
omerb
See mert service ads. We are in the winter. Winter discounted maintenance is going on. If you come across one of them, I think you should take care of it in service. They will put the right oil. If the vehicle has been updated etc. they do it. If you can't find a discount, call and get a maintenance price. The following perception was created in users. Service is always expensive.
Some of the vigilant masters who know this, somehow think that we do not know the service prices, they give a price close to the service. Let's be a little awake, please. I heard this from many of my friends.
08.05.2020 21:22 # 5
Merthinho
yes you say right They said the price was 800 TL from the service. They said that it would be 650 TL with the discount.
There is a master I will go with the advice of a friend. He gave the price of 380 TL.
08.05.2020 21:22 # 6
First of all, welcome to us. I wish you to use your vehicle without accident and good luck. Oil reduction is normal since vti motos are hot engines. as someone who has used 308 vti for 2 years. 10000 km 1.5-2 liters of oil can be reduced. This does not mean that the engine burns oil, and this can be seen in many brands. Especially in gasoline versions. Never add 20-50 thick oil to your vehicle. (The oil you add will not be a problem until maintenance.) Your vehicle's factory oil viscosity is 5w / 30 fully synthetic oil. My advice is to use oil in-engine additives while changing the oil and make the oil change as such. When buying oil between you, turn to quality oils such as motul - liqui moil. If you say why the oil brand is important, the oil evaporation temperatures are higher in the oils I say, because the reduction decreases less in the first maintenance, but you will see that the reduction decreases gradually in the other maintenance. If you complete it by taking 1 liter of extra oil when it is reduced.
as oil
engine cleaner
08.05.2020 21:22 # 7
Merthinho
[QUOTE = sonerkyl] first of all welcome to us. I wish you to use your vehicle without accident and good luck. Oil reduction is normal since vti motos are hot engines. as someone who has used 308 vti for 2 years. 10000 km 1.5-2 liters of oil can be reduced. This does not mean that the engine burns oil, and this can be seen in many brands. Especially in gasoline versions. Never add 20-50 thick oil to your vehicle. (The oil you add will not be a problem until maintenance.) Your vehicle's factory oil viscosity is 5w / 30 fully synthetic oil. My advice is to use oil in-engine additives while changing the oil and make the oil change as such. When buying oil between you, turn to quality oils such as motul - liqui moil. If you say why the oil brand is important, the oil evaporation temperatures are higher in the oils I say, because the reduction decreases less in the first maintenance, but you will see that the reduction decreases gradually in the other maintenance. If you complete it by taking 1 liter of extra oil when it is reduced.
as oil
engine cleaner
We made a mistake. Experience 5-10 again. Tl deb will not escape.
My teacher always recommended Total products for peugeot. I received the fuel in total. I will continue the oils from the total. What is your opinion on this issue?
Recommended oil;
in https://www.hepsiburada.com/total-quartz-ineo-ecs-5w-30-motor-yagi-4-lt-p-otel0530qu004?magaza=hepsibura
Merthinho 2019-11-25 10:25:48
08.05.2020 21:22 # 8
Since the peugeot french is French in total, they agree with each other on the deal with it. The production of suitable oil for psa engines in other oils is not a problem. Turkey sold in total 5w / 30 oils do not recommend refilling turkey teacher. if you are going to put total, you can put french production 0w / 30 totalin. but the price of it is expensive, instead the oils are higher quality. and at higher temperatures, the evaporation rates are lower and the oil will be less in decline. and it will protect the engine.
