WARNING LIGHT
08.05.2020 20:57 # 1
whisky
Hi friends. I had 307 before but sold it for military service. As for 2006, I have joined you again after taking 407 comfort. We are not surprised, of course, from pug: D let's come to my problem. It took more than 1 week to buy the vehicle. As I usually observe, when I take my foot off the gas while driving in 4th and 5th gear, the speed decreases a little and the exclamation warning light turns on when the car is driving with its own acceleration. but it's always in 4th and 5th gear. then when it starts to go normally, the warning light turns off immediately. I searched a lot, I couldn't find anything. I think the problem is turbo or something. going-traction acceleration etc is not all in a spectacular change. Thanks for the help in advance.
08.05.2020 20:57 # 2
GokhaN
good luck new vehicle. According to what he says now, the only solution is to connect and look at the computer
08.05.2020 20:57 # 3
whisky
Thank you. the way of the service appeared then. Actually, it does not have a problem, but if it does not exist, it is irritating. what good tools but spoils pugs :)
08.05.2020 20:57 # 4
GokhaN
I would like to ask that the problem is solved with the machine. Peugeots are exactly the same, but when you look at the car, it is the best vehicles that can be purchased for many years without any problems.
08.05.2020 20:57 # 5
necmettinn
When the warning lamp is lit, is there no text on the information display?
I have a similar problem and my car is currently under maintenance. There was a leak in the injector and turbo. Before the engine was singing, ABS / ESP gave warning, sometimes went back and sometimes gave oil pressure warning. Finally, he wrote that there is a need for engine repair, so I did.
According to my research, I learned that there may be contactlessness in the engine compartment fuse panel, s, z, n can also be such a problem. If my injector and turbo maintenance does not solve the problem, we will consider the fuse panel ... Get well ...
08.05.2020 20:57 # 6
whisky
[QUOTE = necmettinn] No text appears on the information display when the warning lamp lights up?
[/ QUOTE] When the warning appears, I cannot see the information screen is dim. I ordered from the net, I am waiting for your arrival. After installing it, I can get an idea and I have an obd2 device and I will try to look with it. When you pull out of the gas, it usually happens, so the turbo leakage comes to my mind, I think there is a slight black work in the turbo environment. or I don't know my normal situation anymore. I hope that nothing big will come out and I will not cool off the vehicle.
08.05.2020 20:57 # 7
necmettinn
My problem was solved, they replaced a socket that could be intervened inside the fender hood on the side of the belts, I don't know the exact detail of what socket it is. They connected OBDII computer, not OBDII, and detected the PP200 program. Yours could be something like that. Again get well soon...
08.05.2020 20:57 # 8
whisky
[QUOTE = necmettinn] My problem was solved, they replaced a socket that could be intervened inside the fender hood on the side of the belts, I don't know the exact detail of what socket it is. They connected OBDII computer, not OBDII, and detected the PP200 program. Yours could be something like that. Get well again ... [/ QUOTE] Thank you Necmettin bey. I couldn't go to the service yet but what you said in my mind. gotta look through the computer. I also noticed today, while the vehicle is moving at a constant speed, the speed of the vehicle rises slightly, it is not very obvious, but I will ask this service to the service as I take it forward and routine both on the hand and on the road. In short, there is a fluctuation in the revolution while moving on the road.
08.05.2020 20:57 # 9
whisky
I made the change of the information screen yesterday and patience I waited for a warning. but it is not a coincidence that he always burned my feet when he took off the gas, but anyway, it happens once in a while. Luckily I read the tire pressure error on the screen. all the trouble was tire pressure warning. I knew that there was no tire pressure gauge in the comfort model, but maybe because it couldn't measure it, it makes a rascal. anyway i was relieved thanks for the help.
08.05.2020 20:57 # 10
necmettinn
: D: D: D I don't have it, maybe it can be worn later ... Get well soon ...
