Warm air in when the air conditioner is off ...
08.05.2020 14:53 # 1
ereneren
Dear friends, I want to tell you this problem in more detail.
2005 peugeot 307 xt automatic gearbox gives hot air inside the digital air conditioner panel of my vehicle when it is off, the same situation continues when I press the arrow on the top right of this panel, that is, when I say circulate the air inside, the same situation is experienced, even the air vents continue to give warm air inside. I ask the friends who can solve a solution or to help them.
08.05.2020 14:53 # 2
Is the temperature of the air conditioner hot? I think it gives the fan's temperature inside
08.05.2020 14:53 # 3
The simplest solution is to put a valve in the heater hose in the engine part and cut the water entering the inside.
Because the hot water is constantly circulating from the heater core, the temperature is getting in. I guess that there is a problem in hot cold flaps in your vehicles. This time it continues to be warm inside, since it does not cover the heat completely, I think ...
08.05.2020 14:53 # 4
bulent 77
[QUOTE = EmRaH] Is the temperature of the air conditioner hot? I think it gives the fan's temperature I agree [/ QUOTE] inside as low as possible
08.05.2020 14:53 # 5
acad
My friend run the air conditioner first, adjust to the lowest level, then turn off the air conditioner, it will stop giving off hot air.
08.05.2020 14:53 # 6
ereneren
Thank you to the friends who answered, but the weather got cooler. There is no such problem now. If the weather gets warmer, I will try your solution suggestions.
08.05.2020 14:53 # 7
dbmaster
There is nothing to do with the illness of the 307. Cooling out of my mouth when the smoke comes out 38 degrees
08.05.2020 14:53 # 8
YAW FRIENDS HAVE DIGITAL AIR CONDITIONING IN MY VEHICLE I CAN'T OPERATE IN A MORE HOT POSITION I HAVE BREAKING THE COOL NOW THAN 28 DEGREES, IT DOES NOT GET HEATING IN THE AUTODA.
IN ONE OF THESE MANUAL AIR CONDITIONERS WE HAVE HEATED THE FAN WITHOUT USING THE AIR CONDITIONER WITH THIS, I DON'T KNOW I KNOW I HAVE TO WORK TO THE AIR CONDITIONER.
08.05.2020 14:53 # 9
Ozgur
press eco button
08.05.2020 14:53 # 10
alp34
Replace your master thermostat is your only problem, because the weather is cold and the thermostat is a unit that adjusts the temperature, this is the problem, because it is an eletronic tool, but the thermostat is a temperature related situation.
08.05.2020 14:53 # 11
eywlallah eco, our old type is the type that gives the temperature of the engine, right?
08.05.2020 14:53 # 12
http://www.parcayedek.com/home/7802-peugeot-206-termostat-89c-vernet-orj-1336-q1.html
This is the teacher you said
08.05.2020 14:53 # 13
If the engine reaches its normal temperature in a normal time and maintains its temperature and despite this, the heating is not heated, I think this situation will not be related to the thermostat ... the incident should be determined well.
If you say that the engine gets hot at night, we can call it thermostat, or if you say that the engine starts to cool down on the road, we can say it again. But if the heater still does not heat when the engine is warmed up, it has nothing to do with the thermostat ...
Because the water coming to the calorie is removed independently from the thermostat before the thermostat, it comes out of the engine and reaches the inside content. on the other hand, whether the thermostat is bitter or not, whether it is a thermostat or not, hot water comes directly into the vehicle as the engine starts to warm up.
Other reasons why the heater does not heat when the engine is fully heated
1-Calorie pipes may be clogged.
2-heater core may be clogged
There may be air in 3-heating pipes
4-hot cold valves are faulty and may remain in the cold
5-very little potentially water circulation may be weakened ...
the cecol 2010-10-04 09:46:43
08.05.2020 14:53 # 14
thank you very much for the information and importance you gave my cecoli teacher.
