Waiting for electronic solution and Ideas
08.05.2020 17:58 # 1
Feyribas
Hello friends, all of you ... I have shared about sound systems before. These shares were on the equivalent translation. My car is 407 black exe cd version. I converted the original tape to the amplifier output with the deck converter. I have about 40% loss in the audio system in my vehicle. The reason for this is due to the original tape.
Now I want to share my opinion. I have a Pioneer AVH-P4350DVD double din unit that I cannot use. Although I removed the entire front chest for 407 min, I could not place this unit. There was a world iron protection bars in the inner body of the chest.
Based on this, I deployed the Pioneer unit and the hanging navigation style was mounted on the dashboard only on the touchscreen. I put it in the torpedo for the rest of the unit.
My only problem is that I can find the extension of the film strip cable that remains on the screen and the back of the unit, or can I find new film strips about it ....
I am waiting for your help and ideas, friends ...
Greetings to all ...
08.05.2020 17:58 # 2
hsnsnl
teacher, I have friends who connect the amplifier with the deck converter to the original tape 407, 10no 5stars .. you have to choose the branded translator and amplifier very well.
I think you can find the long film strip hard .. I think you can make sole bees, you can carry it out by soldering one by one from the disconnect sockets, there are audio frequency cables, but how healthy it will look at the quality and wiring of the cable.
08.05.2020 17:58 # 3
Alicilik
I think something can be done if it is a photo.
The number of pins of this movie you are talking about is important. For example, something like this can be done;
We first make this movie a normal pinout with the foot. We can extend these pinouts with the help of IDE cables in old cases, then we can pinout this cable end, turn it into a film and enter the case. There's a demi-lengthening, but you'll find two movies and these pinouts.
08.05.2020 17:58 # 4
Feyribas
[QUOTE = Buying] I think if something is photo, something can be done.
Thank you for your attention. Obviously, you are fond of this subject. Are there any omages of the roads in this movie? I will also upload the pictures. Of course, this IDE cable you call may be a problem in terms of aesthetics. If I share the pictures, I think it consists of clearer ideas.
Greetings...
08.05.2020 17:58 # 5
error
teacher, there are three solutions for this job, I sort from easy to difficult
1. to place the unit by trimming the torpedo
2. Going to the places that are dealing with flex cable business, looking for the length of the cable in your hand "Think about the 3rd when this is a difficult event :)"
You have the chance to extend the 3rd film with insulation, "I think you can do it in solder if you are at a level to disassemble the panel and put the body in torpedo :)" firstly, the name of the cable that goes to the panel is flex cable, you will find another one of the same flex cable in your hand, then 2 female sockets are provided for this flex cable. you will have to
ot: If you choose the cable with extension "RF insulation" with screen, you will not have a problem.
As I said at the beginning, it is quite a fine job to solder the flex cable's female, if you don't have the necessary equipment and patience, no contamination is supplementary.
One last note, if your screen is fluorescent lighting and the inverter is on the main unit, not on the panel, you may not light the screen when it extends fluorescent cable from the inverter.
the signal that feeds the fluorescence has high frequency and high voltage and cannot be carried in long cables.
let me insist on option 1.
error 2013-10-05 23:13:33
08.05.2020 17:58 # 6
Alicilik
[QUOTE = Feyribas]
Regards ... [/ QUOTE]
You're welcome. It definitely has an omage, but I don't know if it's equal. An extension may require a module for retrofitting. I can't say something before trying.
You need to look at the photos, but that type of extension cord is hard outside the ide. The film does not last long.
08.05.2020 17:58 # 7
Feyribas
[QUOTE = hsnsnl]
Sir, the installation is quite good, there is a problem in the main unit ...
You can look here ... Greetings ...
http://forum.peugeotturkey.com/forum_posts.asp?tıd=28036&title=sonunda-baardm
08.05.2020 17:58 # 8
Feyribas
[QUOTE = errör] teacher there are three solutions for this job, I sort from easy to difficult
3. you have the chance to stretch the film with insulation, "I think you can do it in solder if you are at the level to disassemble the panel and put it in the torpedo :)" the name of the cable that goes to the panel is flex cable, you have the same flex cable in your hand. you will find more then you will need to supply 2 female sockets for this flex cable
note: If you choose the cable with which you will be extending "shielded with RF insulation", you won't have a problem.
You give very correct advice. I agree but this unit is torpedo, chest etc. I do not bury a world-protecting tubular bars in the chest. All I can put is inside the torpedo or inside the arm rest. But the closest place to the screen is inside the torpedo ...
I will upload the photos, my teacher, I will be waiting for your help after that ... Greetings ...
08.05.2020 17:58 # 9
Alicilik
[QUOTE = error]
it was the 3rd way I said LOL
It can be tried but Big smile
08.05.2020 17:58 # 10
Feyribas
08.05.2020 17:58 # 11
Alicilik
[QUOTE = Feyribas] [/ QUOTE]
long flex would be crippled. I couldn't say there are too many pins LOL It doesn't even look like IDe.
08.05.2020 17:58 # 12
Feyribas
I disassembled the cd drive and it did not even fit in there to replace the original unit.
08.05.2020 17:58 # 13
error
teacher, my curiosity and the environment is not something you can say if you say extension is also good news.
What you need to find is that you will solder the extension cables between the two of the female of the flex cable entering the motherboard between these two teeth.
you will plug the socket coming from the screen to one end of the female and you will insert the flexi you have provided with the same pin number on the other end.
let's say you got the female flexes from the tapes.
above the limit of production in a country such as Turkey is not even a single point by ordering the cable could not solve the problem in two minutes, but unfortunately there are a few companies that produce bespoke flex of this
eg
error 2013-10-06 00:05:56
08.05.2020 17:58 # 14
error
also the ide cable is 40 pins but there are around 50 pins in the pioneer flex.
08.05.2020 17:58 # 15
Feyribas
[QUOTE = errör] also the ide cable is 40 pins but there are around 50 pins in the pioneer flexes [/ QUOTE] as far as I know
All right, do we have a chance to find my teacher? Or wouldn't we make an extension by adding another cable to the legs of the female sockets?
08.05.2020 17:58 # 16
error
two works side by side, there are two key points here
Can you find the flexi that enters the motherboard in the first picture?
2. Can you solder between two female sockets?
08.05.2020 17:58 # 17
Alicilik
http://www.ebay.com/itm/25cm-length-lcd-ffc-50-pins-flexible-flat-cable-2-pcs-for-laptop-screen-/321165950681?pt=lh_defaultdomain_0&hash=item4ac6fb7ed9
I found 50s flex but a little short
08.05.2020 17:58 # 18
error
Unfortunately, the number of ali pins is not enough to match. Unfortunately, the distance between the pins is not important, you can find the flex in the old ink printers and scanners longer than half a meter, but it must meet the metaphor between the pins in the socket.
08.05.2020 17:58 # 19
Alicilik
[QUOTE = errör] Ali is not enough to match the number of pins, unfortunately, if the distance between the pins is not important, you can find flex more than half a meter inside the old ink printers and scanners, but it must meet the metaphor between the pins.
bro, it would be easier if we focused on option 1. LOL
08.05.2020 17:58 # 20
error
Let's say that it is already a brother. Big smile
Page : / 2
