Waiting for 5 30 comments about oil |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:48 | # 1 |
| 08.05.2020 15:48 | # 2 |
metin |
I use 5-30 oil. more precisely, they put this oil in the service. When I researched, I learned that it is good because it is thinner, but because it is thin, the possibility of engine oil leakage. from time to time, you should check for oil shortage. I had it on May 19, when I looked yesterday, there was no shortage.
| 08.05.2020 15:48 | # 3 |
cerci07 |
It is good oil, I use it in 1.4 diesel, I did not have any problem in neither oil reduction nor urbo
| 08.05.2020 15:48 | # 4 |
Which vehicles is this 5-30 oil put in diesel or gasoline ???
| 08.05.2020 15:48 | # 5 |
[QUOTE = 60de106] which 5-30 oils are used in which vehicles, diesel or gasoline ??? [/ QUOTE] It can be used in both ... Unless the engines are hanged, they will not decrease.
| 08.05.2020 15:48 | # 6 |
I know that 5-30 oil is not recommended especially in regions such as Mediterranean, Aegean, Southeastern Anatolia, where the temperature rises above 40 degrees and more.
| 08.05.2020 15:48 | # 7 |
[QUOTE = isodogu] I know that 5-30 oil is not recommended especially in regions such as Mediterranean, Aegean, Southeastern Anatolia, where an oil suitable for Northern European conditions is preferably fully synthetic 5-40 [/ QUOTE] I am also doing 5-40 more. It will be 0-40. Because they are in the same viscosity when they heat up 10-40, 5-40, 0-40. Only cold fluency is different ... But it is more likely to be soured since it is thinner when it is 5-30 hot. I think it is not right to use it in warm temperatures ... But I don't think there will be many problems.
| 08.05.2020 15:48 | # 8 |
turkuaz55 |
[QUOTE = isodogu] I know that 5-30 oil is not recommended especially in regions such as Mediterranean, Aegean, Southeastern Anatolia, where an oil suitable for Northern European conditions is preferably fully synthetic 5-40 [/ QUOTE] Yeah, I think so too.........
| 08.05.2020 15:48 | # 9 |
I do not have any problems with the engine, incontinence etc. to understand. I had 0-30. I rolled the bin, no problem. the oil is of good quality, but the rest is not important. Still, listen to the CeCoLi master. I will use 5-40 in the next oil change.
| 08.05.2020 15:48 | # 10 |
[QUOTE = kapagan] I do not know if there is a problem with the engine, do not miss, etc. I had 0-30. I rolled the bin, no problem. the oil is of good quality, but the rest is not important. Still, listen to the CeCoLi master. I will use 5-40 in the next oil change. [/ QUOTE] Thank you. If you want to use a more qualified oil according to 5-40, you can use Mobile 1 0-40. In cold times, when the engine starts for the first time, it passes to the faster circulation. It is a very delicate difference but it can be important according to what you think.
