Vti engine lpg shutdown
15.06.2020 22:07 # 1
dirt777777
Hello, I have Prins brand LPG installed in my vehicle but I do not use it with LPG I pressed the lpg button from the left of the steering wheel, I switched to gasoline, do I need to do anything to avoid using another lpg, thanks.
16.06.2020 10:06 # 2
No bro, if you want another process, you can go to an LPG dye and make it completely passive from its frog. Also, if you close the valve on the LPG tank, it will become completely passive.
