voyeur problem
08.05.2020 19:08 # 1
PARADOSK3327
Hello guys, when I run the car in the morning, when I turn the steering wheel right and left, ronalti goes up and down and stops. What is the reason, what should I do?
The vehicle is 2006 model and has 206 1,4 8 valve gasoline (atiker brand tube is available)
08.05.2020 19:08 # 2
peugeot murat
THERE ARE OVER THE DIOXION PIPE, THE SUCCESS IS SUCCESSING, AND THEY CAN BLOW AND CANCEL IT.
08.05.2020 19:08 # 3
PARADOSK3327
thank you need to look over the weekend so
08.05.2020 19:08 # 4
themurat54
A friend said here, when he was idling, when he steered left and right, it was normal for the speed to increase and the vehicle to gas. themurat54 2015-03-03 14:38:52
08.05.2020 19:08 # 5
PARADOSK3327
[QUOTE = themurat54] A friend told me when he was idling, when he steered the steering wheel to the left and right, it was normal for the speed to increase and the vehicle to gas. [/ QUOTE]
Actually it was as if I had read it but I couldn't find that comment
08.05.2020 19:08 # 6
themurat54
[QUOTE = PARADOSK3327] [QUOTE = themurat54] Here, a friend said that when he was idling, when he steered left and right, it was normal for the speed to increase and the vehicle to gas. [/ QUOTE]
Okay, I found that it stops when I press the clutch, and I add the link below to the subject I opened, Barbar_35 said.
