Voltran connection cable
08.05.2020 16:22 # 1
Ucyuzalti
Guys, there is no one looking at the voltron properly. I have a close friend but I do not have a voltran connection cable and program in it, is there any possibility to provide them? & nbsp;
08.05.2020 16:22 # 2
Ucyuzalti
Nobody answered, but I found the program
http://www.promannlpg.com/promanlpg1/TR/programlar-1/ now it's time to find ecu link do not find & nbsp; "Big
08.05.2020 16:22 # 3
I couldn't figure out what help you would like. & Nbsp;
08.05.2020 16:22 # 4
Ucyuzalti
An information about whether or not these cables are sold in major cities. What I mean by cable is the cable that connects the lpg brain (ecu) and the pc, there is no here, because my car needs to be connected to the pc for the stop problem "Cry" There is no room, the room is not looking, trying to sell parts, but
Üyüzyüzaltı 2011-11-18 11:28:04
08.05.2020 16:22 # 5
Even if you find the cable, you cannot run the program without a dongle. The tool called Dongle is a tool that tells the program whether the program is licensed and that the program works. Can you run this program you downloaded? Reviews
08.05.2020 16:22 # 6
Ucyuzalti
The program is running in sight, so it is loaded and it hurts the program interface, of course I do not know what the result will be when connected to ECU. Thank you for your attention.
08.05.2020 16:22 # 7
Ucyuzalti
Here is the program interface
08.05.2020 16:22 # 8
Ucyuzalti
In the meantime, the fault light flashes on the LPG in the car, when I put my foot on the gas, that is, when the knob is turned over when I take my foot off the gas, the fault light turns on after a while. ÜÇyüzaltı 2011-11-18 16:42:00
08.05.2020 16:22 # 9
http://www.lpg-kits.com/interfaces.htm
site has such cables and software. It says in the explanations below which lpg kit they are suitable for. However, I think the experience side of this work is important. Even if everything is ok, you will have to do it. You already became a master in that case :)
08.05.2020 16:22 # 10
Ucyuzalti
I'm not going to set it up, satin will make the lpgcide running for years, & nbsp; "Big if the installation is tamm ie & nbsp;
08.05.2020 16:22 # 11
Ucyuzalti
I found the solution, I will use the gas in the city for a short time, stop, and I will use gasoline in the city, I will spend the money with lpg, according to the account, I spend the winter. /> satin does not stop after going 5 km, best gasoline & nbsp; "Thumbs if it stops at the lights, I'll beat someone because & nbsp; "LOL"
