Volante |
| 08.05.2020 17:31 | # 1 |
How do you think the prices are? I am happy with the vehicle, I will volant + I am thinking of changing the triger as well. / div>
| 08.05.2020 17:31 | # 2 |
The same had happened to my friend. While you were watching 307 diesel vehicles like you do, there was a steady knock on the road and sounds of slap. It started to bother more and more and they told you that the mechanic had told you. There was no sound when I changed the flywheel. If you want, show it to one or two more mechanics. Then decide. It is also normal in numbers.
| 08.05.2020 17:31 | # 3 |
I solved the problem for a long time, I could not enter the forum, for those who experience similar problems, I changed the solution of the problem from the mars dynamo. |
| 08.05.2020 17:31 | # 4 |
ahmet_bjk |
The sound from the starter dynamo exists in our vehicle, but it does not bother much, and it comes when the engine is cold or hot. I am not planning to change it for now.
