volante
08.05.2020 15:14 # 1
ask307
Hi friends, I will change the pressure pads in the coming days, I thought that this problem will be eliminated when the car is shaking on departure.
08.05.2020 15:14 # 2
I don't know if they all exist or not, but in the 307s there is a system that they call spring-loaded flywheel. At first glance, it was designed as a system that reduces the hard impact, and this practice, which is seen as functional in practice, brought along a problem like vibration. I cannot say how accurate it is again, but some masters put it in the fixed flywheel and hang the trouble ...
08.05.2020 15:14 # 3
Faruk
I will replace the volantla clutch set. You can see the ideas and prices from friends.
Faruk 2011-04-09 18:49:35
08.05.2020 15:14 # 4
ask307
[QUOTE = Faruk] I will replace the clutch kit with the flywheel. You can see the ideas and prices from friends.
Can you say how many thousand of your vehicle and what kind of problem do you have?
08.05.2020 15:14 # 5
hasimayaz
Some of the 1.4 people have double flywheel. If the hub of the flywheel has gaped, it can knock on the idle and make hard vibrations on departure. If it needs to be changed, there will be 400 - 500 extra charges.
