Voice work
08.05.2020 19:50 # 1
Utkukaraca67
My 307 1.6 hdi 2005 car engine was removed and cleaned. The valves have changed. The new injector was installed. But it sounds loud like a tractor engine. When the valves were seated, the master would straighten, he said, he would cut the sound. Does anyone have information
08.05.2020 19:50 # 2
Generally, the sound should decrease over time. As the master said, I did 1000 km after the engine was built. change the engine oil if you did.
08.05.2020 19:50 # 3
Utkukaraca67
No, it was more than 400 km. What is your suggestion of fat, by the way
08.05.2020 19:50 # 4
I think the master did not inform you, I think that a check is made at the end of 1000 km in engines made to competition, and the oil is changed again. As an oil recommendation, you can choose Mobil and Ay Castrol.
08.05.2020 19:50 # 5
Utkukaraca67
The fats of the oils are different
08.05.2020 19:50 # 6
[QUOTE = Utkukaraca67] The oils have different times [/ QUOTE]
yes 10/40 5/40 oil is suitable for your car but my advice will be 5/40.
08.05.2020 19:50 # 7
Utkukaraca67
The engine started to light up a little after cleaning, is the vehicle normal?
08.05.2020 19:50 # 8
OguzhanKucuk61
Just like zero vehicle, if the oil is changed and checks are made at 1000 km, I think we can call this process a lapping. And it is quite natural that he burned much during the running-in process
08.05.2020 19:50 # 9
Utkukaraca67
Will the sound be cut off when the oil changes?
08.05.2020 19:50 # 10
will be cut at a certain rate.
