voice not found on departures
08.05.2020 18:32 # 1
sabri_23
While my 307 vehicle was getting up, a sound like a snap in front, we could not find a master from the right side, we did not find it, it was like a shock absorber, but they did not look, they say something, but there is a sound while still getting up.
08.05.2020 18:32 # 2
simirnoffredbull
the sound from the front team. guess z rot.rotil.rot head or very probably one of the axles. It would be better if your master looked at these places. Raise the vehicle in 1st gear, stop and go back then go forward again. If it makes click sound,
08.05.2020 18:32 # 3
sabri_23
Can't find a minister, we couldn't figure out where the sound came from
08.05.2020 18:32 # 4
mduran37
He said the same problem is the same problem.
08.05.2020 18:32 # 5
sabri_23
[QUOTE = mduran37] my voice from the left, the same sound goes from the left after the gear to the clutches, when I lift my foot from the clutter, the sound is coming, the sound is the same (the outer axle head) said Check is the same problem.
ewet the same sound as you said it was your voice resolved I wonder what it cost
08.05.2020 18:32 # 6
oguzhan29
The inner axle makes it from the clutch, but it can be from the ears of the engine, but when a friend gets up at one of the inner axle in his car, he was doing it from the ear.
08.05.2020 18:32 # 7
senarist34
brother I had been going by voice for 1 week, where was the rear torsions changed, master, but I went elsewhere I showed the guys raised the car, put the casing under the radiator honey, there is a hose, the screw has fallen, and every time I take off or press the gas, the sound of the two iron is more than one. The axle is empty, without the power to attach it to the head, and the master will find it by car .. :) :) Big smileClap
08.05.2020 18:32 # 8
sabri_23
[QUOTE = senarist34]
brother I had been going by voice for 1 week, where was the rear torsions changed, master, but I went elsewhere I showed the guys raised the car, put the casing under the radiator honey, there is a hose, the screw has fallen, and every time I take off or press the gas, the sound of the two iron is more than one. The axle is empty and it will be difficult to get it by going to the master. Big smile "/> [/ QUOTE]
There is not a lot of masters, nobody, leave the car, not trusted, they have described a master in a last place.
08.05.2020 18:32 # 9
kuscu38
I agree with friends, the axle does what he says. It has a bit like a wire that connects the axle head and the axle beam to each other. It is possible to be from hanger rod or swing bushing, but it is probably the flow head.
08.05.2020 18:32 # 10
blazes06
Lift the hood, look right under the glass in the middle, there is air conditioning gas filling hose.When its head comes out of the metal clamp, the vehicle starts up gearshifts etc. Every time the motor is stretched, it knocks, everybody knows, every master axle ball sounds, the sound is around ... then put it back in place ...
08.05.2020 18:32 # 11
kuscu38
[QUOTE = blazes06] Lift Bonnet look right in the middle of the window, look under the window air conditioner gas filling hose, when its head comes out of the metal clamp, the vehicle starts up gearshifts etc. Every time the engine gets stretched, it knocks, everybody knows every master axle ball sounds the sound ... If it comes, wrap the tape around the clamp, then plug it into place ...
When you said so, my teacher came to my mind, there was a sound that we could not find, as you said in the departures and the yawning of the vehicle. Maybe it will work for you, teacher.
08.05.2020 18:32 # 12
pierson
Hello..when I run the car in the morning, I don't know where the card sounds like a wolf.
08.05.2020 18:32 # 13
halilefe
Have you ever looked at your engine chocks, but have they ever been?
08.05.2020 18:32 # 14
riderzist
I have such a problem, the master said that the axle will change, we changed it, it did not come 1 1 week or I did not hear it, but there seems to be an apocalypse when it goes to the master. the husband changed the axle to me. Changing the axle is your last resort, the problem is something else. I tried to explain this sound to him after changing his balls, but the guy said the ax did not say anything else on Monday, give him a ton of money to do if he will take the axle, but I still become that sound annoyed, or every click on the back and forth, this friend. Avoid the masters who do business with remote listening, without touching the hand, I do not do any more work for him, which I always go on the axle. What happens when the load is on the wheel, so what is the problem in the departure while pulling the foot out of the clutch?
08.05.2020 18:32 # 15
maestro
Brother also had the sound of calista cat, the masters said axle, but with my insistence, the bend of the bend iron was changed.
