Voice I don't know why (Video) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 18:16 | # 1 |
my question is this: The speed of my car is around 70 km and when I put it in 4th gear, there is a thin high pitched noise until it reaches 90 km. this sound alone does not increase as it presses the gas. on the contrary, it disappears as you press the gas. Then, when I put it in 5th gear after 90 km, there is still a thin high pitched voice, but it disappears as my speed increases again. Especially in 4th and 5th gear, it is between 2000-3250 dd. For example, when I drive the car in 4th and 5th gear and bring 4000 dd, this treble sound disappears. I changed the gearbox oil 4 months ago. 2 liters 75w80 total ... It does not happen in 1-2-3 gears. 4. A sound between 2000 dd and 3250 dd in gear. It disappears as you press the gas. My master said that if there was a transmission problem or a 4th and 5th gear problem, as the throttle was pressed, the sound would disappear further. I don't have an open air filter either. original filter ... Why do you think it is? |
| 08.05.2020 18:16 | # 2 |
This topic has been opened in the citroen forum. They even had the 2014 model c4, and when everyone went to the service they said it was normal. The 2011 model has put a friend on a video that has zero km. I added that video here. suffering from the same trouble as me. 3. The hum begins when he shifts from gear to 4th gear. audio starts from the 16th second of the video. do you have this voice? [TUBE] yxo4ltsyjjo [/ TUBE]
| 08.05.2020 18:16 | # 3 |
ozncnercn |
I have the same voice in my teacher, but it starts in 5th gear, thin like humming and normal, whoever I asked where I asked
| 08.05.2020 18:16 | # 4 |
xMEGANx |
I think that sound comes from discs.
| 08.05.2020 18:16 | # 5 |
[QUOTE = xMEGANx] I think that sound comes from discs. [/ QUOTE] he does it in all gears if it comes from discs. Is my actual car I want to learn also available? |
| 08.05.2020 18:16 | # 6 |
xMEGANx |
[QUOTE = maverick] [QUOTE = xMEGANx] I think that sound comes from discs. [/ QUOTE] he does it in all gears if it comes from discs. Is my actual car I want to learn also available? I don't have the same engine, we all have it but I don't, at least. my vehicle 307 1.6 HDI 2007 |
| 08.05.2020 18:16 | # 7 |
ozncnercn |
Whichever vehicle I got on, there was always a hum of 4-5 gears with gasoline-LPG. In my previous vehicle, there was golf mk4. Now I have a car in my car.
