Vibration that shakes the case at 307 fast acceleration (or
08.05.2020 19:24 # 1
dagdelen34
When my car is soft on the gas, it is okay, but when I press the gas fast, there is a sensible shock in the safe, there is no such problem when it is idle, has such a situation happened or does anyone know its solution?
08.05.2020 19:24 # 2
oguzhan53
If there is a gap in the bottom plate bushing, it can do so, or the engine and transmission blocks can also support this vibration.
08.05.2020 19:24 # 3
dagdelen34
Should I show the engine chock with a look, can I understand, if there was a problem in the transmission chock, could the pressure change be understood? thanks for the answer
08.05.2020 19:24 # 4
oguzhan53
With the transmission wedge, the engine top wedge does not easily break down, but there is the engine bottom wedge that the axle passes when it breaks down, and as the speed increases, there is an obvious vibration in the chassis and the steering wheel.
08.05.2020 19:24 # 5
dagdelen34
Is there any possibility that it may be related to the sente setting that I changed the timing? I did 3500 km after changing, I don't know much
08.05.2020 19:24 # 6
oguzhan53
If the adjustment is avoided, the engine vibrates and the engine operates with knock, even the sound of the engine will be different.
08.05.2020 19:24 # 7
muro_60
there are springs in the internal flows, they can break and shake, shake the case when it gets on the gas, if you get out of the fiber, it can slip off the ground
08.05.2020 19:24 # 8
dagdelen34
There is no problem in the synth setting, then there was a punch called the ax tulip (masfal).
08.05.2020 19:24 # 9
muro_60
look at the internal flows what i have to do with the sentence i wrote above
08.05.2020 19:24 # 10
Ademkrks
Vibration problem is present in me. It is felt at 2800 and 3000 revolutions. It is generally felt when the vehicle is overwhelmed. Ademkrks 2020-03-11 09:42:28
