vibration on the brake pedal
08.05.2020 17:48 # 1
yavuz_0051
I bought 4 new tires for my vehicle, there was tremor in the steering wheel, the rod was cut after the start, but the brake pedal started to vibrate (not doing it at low speeds above 90 100) I think my guess might be from the disc, waiting for your answers ... & nbsp;
08.05.2020 17:48 # 2
Serkan
As you might have guessed, it's probably from discs.
08.05.2020 17:48 # 3
You can make new tires too, sometimes the tire needs to get used to the car, maybe you can do it too. & nbsp;
08.05.2020 17:48 # 4
ysndrsn
what could be the cause of hardening of the brake sometimes in my vehicle
08.05.2020 17:48 # 5
pt206
After the brake is applied to the brake, the pad and discs harden (swell) due to the increase in temperature, it is normal. I think that the hardening other than this may be caused by the pad.
08.05.2020 17:48 # 6
vbmaster
Never use water with discs that become hot during long-term braking use.
08.05.2020 17:48 # 7
error
[QUOTE = Alper`EN AKSU] he can make new tires too, sometimes the tire needs to get used to sit on the floor, maybe he can do it too & nbsp; [/ QUOTE]
