Vibration in Gear
08.05.2020 17:07 # 1
yigit4516
While driving at 80-90 km speed, vibration occurs on the motor side and the front side vibrates by making a right to the left. It shudders in gear in the same way. Especially he does a lot in 4 gears. This is very evident when the vehicle is heavy. The balance adjustment has just been made. I even asked the balancer, for what reason, he said from balance. After doing it, it looked as if it had improved, but after a while, there was no change. What would be the cost of the axles?
08.05.2020 17:07 # 2
hsnsnl
it can be from axle tulip ..
08.05.2020 17:07 # 3
Barut
usually does from axles.
08.05.2020 17:07 # 4
yigit4516
[QUOTE = hsnsnl] can be from axle tulip .. The output part is 150-200 degiso [/ QUOTE]
Output 150-200 tl & nbsp; & nbsp; How much can zero know ...
08.05.2020 17:07 # 5
hsnsnl
My teacher will bring the vehicle to the top of the vehicle and come under the vehicle and swing the axles. If they are doing a very solid weld to their interiors & nbsp; they are getting their original shape & nbsp; they are repairing the axle and whether they are testing it in the simulator. If you come in, it is from him.
08.05.2020 17:07 # 6
MagicPerformance
If the vehicle is equipped with a sports exhaust system, it makes a tremor when it is overturned.
08.05.2020 17:07 # 7
inceyasar
Are there any places in Ankara that you know to repair axles?
08.05.2020 17:07 # 8
yigit4516
I went to someone doing axle repairs today. He lifted the car and controlled the right and left, the right side playing a little too much. He said nothing on the left. We ripped it and opened it, there was no oil left, and the place where the mackerel wandered was worn. He filled it with welding and grinded it to reach the same level. Then he gathered it and put it back on. I tested the vehicle, and the problem was solved. The gear shuddered a lot, and he left. As he says, the supplier industry would be better than parts. I had a total of 115 TL. They said the price of the supplier industry was 200 TL. It was very beautiful this way. Hopefully it won't be a problem in the future.
08.05.2020 17:07 # 9
hsnsnl
You made the number 10, I don't think the problem will arise in the boleye
08.05.2020 17:07 # 10
inceyasar
Where did you get bro?
08.05.2020 17:07 # 11
yigit4516
[QUOTE = inceyasar] Where did you get it brothers [/ QUOTE]
Tornacı İlhan in Bursa in small industry
