VIBRATION IN CLUTCH
08.05.2020 17:05 # 1
FeverDog
FRIENDS HAVE STARTED TO MAKE A VERY DIFFICULT TO ME IN THE LAST DAYS, WHAT IS THE NAZAR? There was a tremor, as if driving the wiper onto dry glass. I checked it over and over again, obviously there is a problem. When I pressed the clutch after turning off the ignition, it was the same as in normal time, there was no vibration or friction.
Ağalar brothers help :)
08.05.2020 17:05 # 2
muro_60
Clutch ball makes it up when getting up, if there is a tremor, it is a bit that will start it :)
08.05.2020 17:05 # 3
FeverDog
yes I said it too; As you get up, some quizzes are happening today. napçaz? :)
08.05.2020 17:05 # 4
muro_60
:)) unfortunately, I can pull the handbrake up, take it up, take off, look at the bag, my bag, the smell of the bag & nbsp; or take it off on the ramp, if I am screaming, 500 TL is going to invest in the lion :))
08.05.2020 17:05 # 5
muro_60
By the way, mine is finished & nbsp; "T
08.05.2020 17:05 # 6
FeverDog
Even if you pass by, brother :( the traction is weak, it is shaking a lot in the departure. Also, when I run today, there was more strange sound coming with the engine sound. I continued, I even felt that the sound came from under the brake pedal, when I pressed the brake or something.
08.05.2020 17:05 # 7
Gargi
I think your problem is caused by other pads and flywheels. My car was 307 hdi and I went to the service due to the vibration in the departures and a sound similar to the sound you described from the engine, they made a figure about 1800, until about 3, 4 months ago, but as I said, I think that the main source of the sound is volant. .
Reviews
08.05.2020 17:05 # 8
FeverDog
I hope you get well done, if you still use it that way, but I hope it won't cost you much better. I'm depressed now :)
08.05.2020 17:05 # 9
Gargi
I had recorded the voice to get an opinion about the cause of the problem, the more dominant voice ended with the change of my circulation, but after changing the money in the service, we realized that a similar voice continued. The vehicle was removed again and we found out that the sound originated from volan. I share the video and compare it with the sound from you. & nbsp; & nbsp;
& nbsp; & nbsp;
08.05.2020 17:05 # 10
FeverDog
Yes, the sound is the same as far as I can hear from the phone, but now it sounds quite loud and comes from the clutter. I'm afraid to use it: /
08.05.2020 17:05 # 11
muro_60
change it, but get the original pad, have a problem, come easy :)
08.05.2020 17:05 # 12
FeverDog
The service for the press brake clutch wire gearbox oil change has brought out 850 million prices.
